Question about SanDisk Sansa Clip MP3 Player
Not Compatible I am running Vista on my laptop and i already tried the "hold the volume +" thing. It is still saying that the driver installation failed...any ideas?
  • 758 Answers
Follow the link below to obtain the driver for your device..Select your device model and operating system.....
http://www.sandisk.com/DriverDownload/index.asp
I hope this helps..
Please rate accordingly
Thank you
Computerrep
Posted on Apr 21, 2008
Connecting Mad Dog to PC
all light scribe should be compatible with windows vista ..the issue is to install the correct program and driver to operate it ..If it has the interface to connect it ..and it sees it and accept the driver ...will work ..It does not depend on the system configuration ...cause if it runs vista its already fast enough and have at least 1 G of ram ..
Dec 11, 2011 | Dell Inspiron 1525 Laptop
Dear expert, salute, I got my Sony Vaio laptop today and got a lot of problems. It is VGN-FZ220U Model and it's been used by my brother for a couple of years already. It had Windows Vista Ultimate...
You can download Vista Drivers from sony's website and right click on the setup file go to properties and then select run this program under compability mode. this may help you on your driver issues also make sure that you install the drivers for the correct OS you have installed (32bit or 64bit) On the Webcam issue you have to play around with a couple of drivers since this were not written for win7.
Hope this helps!
Aug 04, 2011 | Sony VGNFZ220U/B VAIO FZ Series...
I'm running XP Pro. Trying to install
you should check the compatibility of the drivers you are installing with your windows xp, it may be designed for vista or 7, then If it is already compatible, try to plug the card first and then run the setup.
Jan 27, 2010 | D-Link Platinum RangeBooster N DWA-642...
Vista can't detect de DVD rive LG gh22ns30
If u are using vista then do not install any extra driver for any removable drive. In vista one cannot install any drivers other those already in its database. I hope your DVD drive is Vista compatible, otherwise it will behave the way you mentioned it..................sodeep
Jun 28, 2009 | ASUS P4B533-VM Motherboard
No sound
TRY INSTALLING AN AC'97CODEC DRIVER FROM REALTEK.RICHARDM69
Dec 15, 2008 | Gateway 4540GZ Notebook
Is the canon multipass f60 compatible with windows vista (on an hp laptop)?
Canon does not offer Vista drivers for the MultiPass F60. Vista may have some generic drivers that will work, so don't delete or over-ride them in the system.
The major problem is that the printer only supports USB 1.1 and not USB 2.0
Here is a link to Canon's MultiPass F60 Printer site ...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7174
Sep 20, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Does not recognize
Ahh - you have Vista! You MUST get the newer version of the software from www.usasupport.philips.com. Enter your model number and go to the "software & drivers" section. Download the updated version of the device/firmware manager. Once the Vista-compatible version of the software is installed, then you can go to the Update tab and the firmware upgrade that you need will be installed - you will not get the "your player's firmware is already up to date message."
Jun 18, 2008 | Philips SA5125/37 MP3 Player
30gb zune install
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 21, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
IOGEAR GBP301 and HP Deskjet D1341
Please make sure that the printer is already VISTA compatible meaning if it is known to have VISTA printer drivers.
Jan 17, 2008 | IOGear GBP301 Print Server
Printer
Obviously you have already tried to without success or else you would not be posting to this site. The answer is two-fold unfortunately. Sometimes manufactures cannot keep up with tech changes in OS and there is a driver update lag. If you did try to no avail, it means the install disc/driver is not updated enough to be compatable with vista. You have two choices. Run xp on your laptop instead of vista or go to Hewlett Packard web sit (google it) and go to download section. Download the update driver that is vista compatable if there is one available. Now, install the printer on you laptop using this new driver. Back it up on disc to avoid losing it and having to download it again.
Sep 01, 2007 | HP Deskjet F340 All-In-One Printer
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
