Question about Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
    Guru:
  • 195 Answers
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Posted on Jul 18, 2010
  • 390 Answers
SOURCE: paper will not feed
Check for a jam again somewhere in printer unit, rollers, teeth, down back in paper feeder area. I thought i had no jam in my unit either until i got a torch and found the tiniest slip of a shred barely noticeable right in the middle of the teeth/roller. Remeber to turn it off after this, to reset it.
Posted on Sep 01, 2007
SOURCE: Not printing
Had the same problem - in the end it was that the paper drawer wasn't closed properly.
Posted on Apr 29, 2008
edandgreta
SOURCE: paper won't feed
My CX4800 developed the same problem. It was an excellent machine until then. I tried everything I could think of, and finally decided it must be the rather large feed in rollers at the right of the paper bin (one below and one above the paper) that had worn too smooth to pull the paper in. It works fine if I will give the sheet a "push" when it starts to go down - but who has time to stand there and push each piece in! It would really be nice if Epson would provide us with inexpensive replacement rollers and instructions for installing them. Guess they had rather we just buy a new printer - which I did, a CX7800, only to find that it will not take the heavy weight photo paper. :-(
Sorry I couldn't help more.
Posted on Aug 04, 2008
  • 21 Answers
SOURCE: printer keeps saying paper jam..there is no paper jam
You can also try using a rubber eraser as the rollers are going. Just take a pencil and lightly rub along the length of the rollers as they are feeding. This should remove the film that clogs the rollers surface.
Posted on Jan 14, 2009
SOURCE: paper does not feed into lexmark X5470 all in one printer
Rollers could be worn out. Also could be a problem with the paper sensor. Not sure what type of sensor this printer uses. Some just use a pressure switch, others use a light sensor.
Posted on May 18, 2009
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
Paper not going through feeder paper going off to one side of printer
Usually this is caused by a piece of torn paper occulding the paper path. or a shiny area on the paper feed rollers.
1) for paper jam: Use a peice of stiff card and place it in the printer use word pad to print a single full stop and that will start the card to begin to roll through the path. apply some push to it to keep it straight in the effort to snag that paper and have it ppushed out of the rollers
Yse a plastic polly mit and run over rollers to slightly roughen them and remove the ink shoine on them, especially the side that has the problem.
Feed a new piece of paper into the printer and check that it is now printing correctly
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper Jam. It starts printing and stops half way through its print cycle, says paper jam, in fact their is no jam.
check if this is happening from all trays... if such clean the paper feed rollers... if still happening clean any other rollers in paper path... if still happening then you have a bad sensor that keeps tripping at the wrong time... but more than likely this is only occuring with one tray... clean your feed rollers and it should be ok... still not ok... then replace feed rollers... there is also the possibility that your fuser is shot... your can tell if your fuser is shot if... when you put your hand near it... it doesn't feel like it could burn you... if you can actually get to touch it and its cool to the touch... then you got a bad fuser...
Dec 18, 2009 | Office Equipment & Supplies
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
Not printing
There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
Thoroughly check the paper feed path.
If not working, then check/clean the rollers.
Jan 20, 2008 | Kyocera FS-720 Laser Printer
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
253 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
