Question about Acer Computers & Internet
I have just reinstalled windows XP pro I have downloaded the drivers from your driver downloads, yet I am still unable to get an internet connection because it says my laptop has not got a net addaptor fitted, which cant be true as I was using it ok befor the re-install, do I need a driver or what that I have not got? Thank you.
  • Acer Master
  • 4,737 Answers
Please let me know your Laptop's Name and model. Let me help you fix this. Yes, you may need to reinstall the drivers or it's possible that you haven't installed the Chipset drivers. For all these, I need to know the Model Name of your laptop so that I can assist you.
Need your immediate response.
Awaiting.
Thanks.
Posted on Jul 18, 2010
  • 6 more comments
  • mrwright1 Jul 18, 2010
    It is an Acer Aspire 5100
  • Lebanon Raingam
    Lebanon Raingam Jul 18, 2010
    Thanks. Now first of all let's try to install the Lan Card Drivers.
    Open this link (click here to open acer home page)
    or
    http://support.acer-euro.com/drivers/not...
    and click;
    As soon as you click the "Arrow" tab, you'll see drop-down lists like this;
    Move down your mouse to "Lan Driver Realtek Ver 5....." and select it. Download will automatically begin. You'll need winzip or winrar to extract the driver files. It may take few minutes depending on the speed of your connection. The size of the file is 4.8mb.
    After the download's completed, extract the files to a folder (create a new folder and name it as you'll remember when needed). In the new folder, locate the "Setup" file and run it. Follow the onscreen instructions and click "finish" when installation is completed.
    If this isn't successful, please let me know.
    Good luck.
    Thanks for using FixYa.
    Hi, I seem to have further problems now, I did do as you asked and downloaded the acer Lan program onto my PC, now when it says restarting your PC it turns off, but when starting up again I get the normal acer screen where it says at the bottom of the page "Press F2 to go to settings then I get another window opens which tells me to press F1 to resume or F2 for settings, then after pressing F1 another window opens telling me to start Windows normally or last known best settings etc, so I press open windows normally, then windows window opens up and does nothing just freezes and I have to turn off the laptop by the switch, and having repeated that a few times I just get the same set up, so I left it for a couple of hours then on repeating everything again and clicking F1 to resume and then start windows normally windows opens, but when you close windows and try to start it again the same thing happens.
    Is it because I might have loaded things on twice as I have been to the acer site before on re-installing windows, and downloaded all the necessary downloads needed, and by the way, although I can get a menu saying what wireless internet connections are available and then loading my own on it connects to BT but still will not let me on the internet, as when I put the BT disc in it comes up that my pc has not got wireless connection or I have not got an adapter fitted in my laptop, yet I used to get on the internet before with this same laptop, I hope you can help. Thank you.
  • mrwright1 Jul 20, 2010
    What has happened with your advice, since doing as you asked I have big problems now as I wrote last time, but now it seems you are ignoring me, and I really would like to get my laptop back on track, because all it is doing at the moment is frezzing on the windows opening page, and there it stays.
    Thank you URGENT
  • Lebanon Raingam
    Lebanon Raingam Jul 20, 2010
    I am sorry for the late reply. I wasn't able to come online since yesterday as I was travelling. Well, the problem could be drivers conflict. Had you install any Lan drivers before....? Well, there's nothing much to worry, let's do it like this.
    Power on your System, press F1 when as and then press F8 several times, you'll be directed to the Advanced Boot Options, from there, select Safe Mode (you can also try "Safe Mode with Network"), and follow the onscreen instructions, (loading may take some time with black screen and white texts). If you see any message, give positive inputs. Now uninstall the Lan drivers, run a registry cleaner and restart your system in Normal Mode and reinstall the drivers. (you can download a registry cleaner from this link if you don't have one)
    If this doesn't work, again boot into Safe Mode and restore your system to previous state (date) after it's successful, install the Lan driver. This will definitely fix your problem.
    If you have further problem, let me know.
    Good luck.
  • mrwright1 Jul 21, 2010
    Hi well I have tried all you said, I could not see what I had to do when I clicked safe mode, because all that happened was a black screen with white writing and it did nothing only stay there until I switched it off, I can load an wireless network on such as BTHomeHum-D2C4 but it will not put me on the internet for some reason, and all I get is something saying cannot find net adapter, yet I have loaded the drivers down for Atheros wireless adapter and Broadcom wireless adapter, but it still says it cannot find the net adapter? according to my device manager the only other thing that has not loaded is something called PCI as there are two yellow question marks by the side of these items in device manager, does this help at all.?
    thank you for your help.
  • mrwright1 Jul 25, 2010
    It is now 4 days since I got a response from you to my question, if you are unable to help with this can you please pass it on to someone who can help as I thought I would get a quick soloution to this problem not have to keep waiting days before i get a response and then having to write to ask what is happening.
    Thank You.
  • Lebanon Raingam
    Lebanon Raingam Jul 25, 2010
    I am sorry, I thought this questions had been passed to another expert few days back so I didn't respond your posts as I thought they were for the other expert. Well, I opt out.. I am sorry that I can't give you better solution. I could only wish you good luck. But please note, all the posts you sent to me will not show up to other the other experts, only to me and you. And same thing with anther expert, I will not be able to see his/her posts. Most users got confused with this and they are frustrated explaining the problem again and again. FixYa does this because, every expert should bring up a unique solution without copying others'.
    Good luck.
Can't connect to the internet new hard drive installed, windows XP pro installed when checking hardware : says ethernet controller driver - not installed. tried finding it on the installation CD, get a...
You need the Intel Pro 100 driver for XP. Go to the following web link at Intel: http://www.intel.com/p/en_US/support/highlights/network/pro100ve and download the driver. Copy it to a flash drive. Put the flash drive into your PC that needs the LAN driver and double-click it to install it.
Oct 25, 2010 | Microsoft Windows XP Professional
Reloaded windows xp and now i am unable to connect
Hi, First option is to locate the Drivers and Utility Disks that came with your computer and use it to re-install all drivers; especially the one that allows you to connect to the network / internet service. Second option is to go to a computer (maybe a cafe) that is connected to the Internet, go to the support page of your computer manufacturers website, download the essential drivers you need, save them to a USB / Flash disk and then go install on your own computer.
Apr 30, 2010 | Everex GA3400 PC Desktop
I have toshiba satellite pro L310.But i couldn't find software CD.but in the internet there is drivers for toshiba satellite pro L300 model.Is there is a equal those two drivers?how can I get drivers for...
Here is the link for driver download for Windows XP
http://www.getpcmemory.com/drivers/download-toshiba-satellite-l310-notebook-windows-xp-drivers/
Download it.
That's it
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
Can't install drivers on Lenovo T 60 after XP Pro reinstall
go to device manager, uninstall network adapter, reboot, windows should find and reload drivers.
Nov 02, 2009 | Lenovo Thinkpad T60 Notebook
Hp compaq dc5100 mt pz581ua ethernet drivers
TRY THESE DRIVERS
MODEM_AND_HP_WIRELESS_ASST
http://rapidshare.com/files/286881164/MODEM_AND_HP_WIRELESS_ASST.rar
BROADCOM_WIRELESS_DRIVERS
http://rapidshare.com/files/286884551/BROADCOM_WIRELESS_DRIVERS.rar
INTEL_PRO_WIRELESS
http://rapidshare.com/files/286884550/INTEL_PRO_WIRELESS_sp31678.exe
Sep 30, 2009 | HP Compaq dc5100 Desktop PC - Intel...
Formatted and reinstalled win xp, no internet drivers
in case that u do not has the driver cd, u can download cpuz in order to detect what kind of motherboard of your machine so that u can download the respective drivers. After install, your pc should be able to online.
*Suspect LAN driver not installed thus cannot online
Jul 20, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
No Networks Recognized when I upgraded to XP Pro
Are you using a wired or wireless connection?
Check the Device Manager to see if there are any missing drivers or yellow exclamation points.
Report back.
Mar 10, 2009 | Acer Aspire™ T180 PC Desktop
Windows Xp
In addition to installing the operating system (Windows XP) you will need to install the drivers for the system.  If you system is a Dell Dimension 1100 you can get the drivers from this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_1100&os=WW1&osl=en&catid=&impid=
Driver installation order is:
Desktop system software (R121089.exe) Intel Chipset Utility (R96614.exe) Intel Video Driver (R104515.exe) Audio Driver (R105155.exe) Network Driver (R105786.exe) Modem Driver (R133743.exe or R73044.exe)
Once you have all the drivers installed, then you can install your applications and configure your internet connection.
Sep 07, 2008 | Dell Dimension 1100 PC Desktop
Computers & Internet Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
