Question about JVC KD-G120 CD Player
Does it have a fuse inside ? - JVC KD-G120 CD Player
  • 15,935 Answers
All fuses are external.
You will find them on the red and yellow wires on the harness.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 18, 2010
08 ford lariat f150. Fuse 14 keeps blowing. The starter engages while running and blows the fuse. The starter is not on fuse 14, any suggestions?
What engine ? Fuse 14 , where > under hood fuse box or inside fuse box ? If central junction box inside vehicle ,that fuse powers the heated PCV - positive crankcase ventilation valve . 10 amp fuse . Also powers ,digital transmission range sensor . Your digital range sensor is probably shorted inside . This could cause the problem your having .
5+h+y40chxaaaaaelftksuqmcc
Mar 22, 2016 | Ford Cars & Trucks
Change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside
An iron should be calibrated to 410 degrees on wool setting to get the other settings to work correctly.
Dec 26, 2012 | Irons
Television has no power. outlet has power and cord from outlet to television has power. is there a fuse?
All telivisions has fuses inside. Some of them has one, and some has two. If your tv doesn't power on, and power chord and outlet is ok, surely the fuse inside may blown out. There may be some reason for the blowing of fuse. Fuses are used inside tvs are for protection purposes. f any overvoltage or over current taken by the system, the fuse will blow out. you must fist find out the resom for the bowing of fuse. New fuse must be put in only after that check. Otherwise you will spoil the whole circut board inside the tv irrepairable. Concat a service personnal, and let him do that. Ok.
Remember, different tvs have different power ratings. Must select proper fuse according to the ratings.
Oct 13, 2010 | RCA 32F531T 32" TV
Has no power to inside fuse box Accidently arched battery now we have no power to the inside fuse box. The car will start but not go into gear even with break engaged. The tach , heater , electric windows,...
thats cause u blew the main fuse..... its a 80 / 90 amp fuse under the hood, under the fuse panel.. The fuse has to be bolted out it cannot be pulled out..
May 06, 2010 | 1997 Toyota Camry
Describe how I access the inside fuse board?
I checked my Camry's manual which described how to open the cover over the board. The diagram on the inside of the fuse board cover identified the location of the cigarette lighter fuse. I replaced it with the spare 15amp fuse found in the other fuse box next to the engine block, also described in the manual. However, this did not correct the problem. On a hunch, I pulled the fuse labeled "power point" and saw the burnt filament in the fuse and replaced it with the 15amp fuse. This corrected the problem.
Jan 26, 2010 | 2004 Toyota Camry
My windshield wipers fluid motor stoppped working,is there a fuse I need to replace.I have a 2007 ford edge
Hi the chances are its not a fuse thats gone its more likely going to be that the motor has seized this happens if it hasnt been used for a while.
If you look inside the fuse box you should see printed on the inside lid the location of all the fuses and if its not written on the inside of the fuse box then the chances are it is going to be written inside the owners hand book, so look in their and then check the fuse for that part.
If you cant find any fuse location instructions then just look inside the fuse box and replace any fuses that are blown if you find any then if it is a fuse you will find a blown one and then should solve your problem.
So if you find no blown fuse then the chances are its going to be the motor this would need testing to see if you hed power going to it if their is no power going to the motor then this would indicate the switch itself was faulty and would need replacing.
Let me know how you get on or if you need further assistance ok
Jan 03, 2010 | 2007 Ford Edge SEL Plus
Since the inside fuse cover for my 1991 Acura Legend is missing, I do not know where each fuse goes. So, I need a diagram for the inside fuse box. Thanks
google it! but all you need to know is that with key turned to on position most all fuses are on so you just test each side if the fuse with test light if it lights on one side and not the other then the fuse is bad also remember there are fuses inside car and outside in engine compartment
Jan 03, 2010 | 1991 Acura Legend
Cant find the fuse box (inside the car)
check all the fuses the horn is sometimes put in with other fuses hope this helps regards Jim
Apr 07, 2009 | 2005 Suzuki Swift
I have a 93 LeSabre and the windshield wipers and the horn are not working
Look for a fuse inside cab, where fuse panel, or fuse box inside motor compartment, first look for it inside, it will tell you which fuse it is, if You can't find it look on owners manual
Jan 24, 2009 | 1993 Buick LeSabre
My cd/radio all the sudden stopped working maybe fuse??
There are two fuse boxes. One is located on the kick panel in front of the passenger side seat. Remove the big cover. Inside there is a second cover that ultimately gets you to the fuses. Try #20 (reference the template on the inside of the cover). There is a second fuse box (high current fuses) inside the engine compartment (on the passenger side of the compartment, big square plastic box). Fuse # 56 (reference the template inside the cover of the fuse box). Same deal.
By the way, there is a fuse removal tool inside the interior fuse box (white plastic piece on the left side of the box). You will need that removal tool to work on the ones in the engine compartment. That other box doesn't have a tool.
Hope this helps.
Nov 17, 2008 | 2006 Ford Mustang
JVC KD-G120 CD Player Logo
29 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
