Question about Cameras
I have a Coolpix 5400. I get a "lens error" msg on the screen when zooming the lens. Also the AF and other light on the viewer flashes when this happens. At this point,the camera becomes inoperable.
    Sergeant:
  • 202 Answers
If ginko's suggestion doesn't work out,...
Please, check THIS Nikon advisory regarding your camera. You may qualify for "complimentary" service to repair the cause of the issue you're experiencing.
This is the 1st time I've seen this for a consumer product. You have to submit a request through Nikon in order to receive a replacement manual. It cannot be viewed or downloaded from Nikon online. (I was attempting to find your manual or any documentation w/ references to trouble-shooting the issue you're experiencing.)
HERE is Nikon's FAQs for instruction manuals.
That's OK, though. You can find the manual HERE.
Just enter your camera's model number.
Posted on Apr 21, 2008
  • 1 more comment
  • B Joan Rapier
    B Joan Rapier Apr 21, 2008
    My apologies to the other experts who posted. ginko's was the only one that I knew of at the time I had my post ready to submit.
    dbaker1928, please, review ea of the solutions offered. You may find that two or more of the solutions lead you to resolving the issue you're experiencing w/ your camera. In that event, it's perfectly OK to assigne FIXYA ratings to each of those solutions. (In other workds, you can assign FIXYA to more than one expert contributor's soltuion.)
    Thank you
    BJ @:)
  • B Joan Rapier
    On page 152 of the Instruction Manual:
    LENS ERROR=Lens operation error
    Recommended Action: Turn camer off then on again. If error persists, contact retailer or Nikon representative.
  • B Joan Rapier
    This may be a case where you can take advantage of the complimentary service offered by Nikon that I mentioned earlier. (referencing their service advisory for the camera)
  • 477 Answers
You have a damaged lens sometime dust , sand, or dirt can get in the lens gears and when ever you try to zoom it hits the obstruct and causes the error. This is a very common problem. you can try some compressed canned air and blow around the lens and see if that fixes it but if not it will need to be serviced. lens cleanning can cost anywhere from 30.00 and if the lens is damaged and need to be repalaced it can go over 100.00 I charge for a lens 85.00 plus shipping if that is all it is for this type of problem. I hope this helps.Let me know if you need anything else.
  • 758 Answers
It is a pretty major problem for the Coolpix it seems. The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system. It could have been something as small as a bump while it was being carried in your pocket. The problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that Nikon says happened during usage.
Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Nikon first and see what they have to say about cost of repairs. Other people say that once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
Good luck.
Computerrep
    Master:
  • 788 Answers
Does the lens move in or out at all when you press the zoom buttons? I bet it doesn't, I think your zoom mechanism is at fault, the lens is not moving in or out. You may want to try to open out the camera and look at the model and gearing for the optics, but this may be a little difficult and could damage the camera further if you are not careful.
  • Dean Joly
    Dean Joly Apr 21, 2008
    Sometimes givin the camera a switch hit will dislodge the mechanism. It's worth a try since having the camera repaired will probably cost more than a new camera.
    If you are willing to try most people have had luck with gently tapping the bottom of the camera while it was powering up.
  • Cameras Master
  • 19,396 Answers
Your lens are jammed try firs pulling out and putting back batteries
  • Ginko
    Ginko Apr 21, 2008
    If your camera returns Lens error, then there is an hardware problem problem with the lens/zoom. Usually dur dirt or a broken, deformed part inside the lens cause this.
    The easiest fix is usally when camera is not starting at all because lens do not open, in this case you gently tap withthe palm of your hand the back of your camera and lens often pull out, another technique ids pulling out the lens with fingernail while starting the camera.
    If the camera is fully operational, and return lens error only when you extend the zoom , or randomly then problem is more difficult to resolve. It means there is a lose or defective part inside the lens mechanism. You need to disassemble the lens block and mount it back.
    I should have the whole procedure for it somewhere, but I suggest contacting an authorized service, as you may risk making your camera completely unusable forever, if you do not have the right know how.
What is 55-200mm?
That's the focal range of a zoom lens. Unlike a single focal-length lens (or a "prime" lens) a zoom lens lets you adjust the focal range. "55-200mm" specifies the lens's focal range from 55mm at the low end to 200mm at the long end.
You can read a general description of zoom lenses at
http://en.wikipedia.org/wiki/Zoom_lens
Nikon current has two different 55-200mm lenses:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/
2156/AF-S-DX-Zoom-NIKKOR-55-200mm-f%252F4-5.6G-ED.html
and
If you're asking about the L110, it has a permanently-affixed lens and will not use either of the above lenses.
Aug 11, 2011 | Nikon Coolpix L110 Digital Camera
My zoom doesnt work and i geta lens error msg
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Dec 12, 2009 | Nikon Coolpix 4800 Digital Camera
Nikon coolpix 2200 zoom problem
I was having a "Lens Error" with my Nikon Coolpix S210 camera and this websites' tips fixed my camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 16, 2009 | Nikon Coolpix 2200 Digital Camera
Exact same troubles.
i think you've got a stuck zoom in [+] button. was this camera left inside a cabinet ...or some damp place for some time?
Jul 15, 2009 | Nikon Coolpix 2200 Digital Camera
When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Dec 17, 2008 | Nikon Coolpix 5400 Digital Camera
Coolpix L1 Lens error.
Seem like the AF system doesn't reach the home position, therefore the zoom is not closing. Or may be has been smashed and the zoom block is jammed.
Anyway you need professional help. Problem will be solved after a major srip down.
R. Calla C.
Oct 22, 2007 | Nikon Coolpix L1 Digital Camera
Flashing "f--"
"F-- means the CPU in your AF camera body cannot communicate with the CPU inside your lens. That means either your lens is an older manual-focus one and has no CPU or there is some electronic communication problems.
If you have an AF lens on your camera and still get F--, I would first clean the electronic contacts in the lens mount area, on both the body and the lens."
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00JCKn
Hope this helps!
Oct 06, 2007 | Nikon D50 Digital Camera
Cameras Logo
74 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
