Question about Cycling
Peugeot, speedfighter, electric start does not start when i press the break and the yelllow button on the right hand side, and rev it does not make a sound its lie the bike dead. But when the key is turned the petrol gage still rises, the horn indicators and everything else works . The kick start is also dead its like theres life and theres no life if you no what i mean ..Some 1 hel me please
Posted on Jul 28, 2010
2003 Peugeot Vivacity 50 will not rev
Hi, Miggy and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
PEUGEOT VIVACITY WON REV HELP
https://www.scootershack.co.uk/threads/speedfight-wont-rev.16095
PEUGEOT Vivacity Workshop Manual
Peugeot Vivacity 1 50cc
PEUGEOT Vivacity Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 26, 2018 | 2007 Peugeot Vivacity 50
Will this fit on my speedfight 2 50cc??
Hi, Brodie according to the information on the screen snapshot you provided yes it will fit on your scooter for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.49ccscoot.com/manuals/Peugeot_50_Vertical_2T_Engine_Manual.pdf
PEUGEOT SpeedFight 3 Workshop Manual
Peugeot Speedfight 2 2006
Jul 20, 2016 | Motorcycles
2002 Peugeot Speedfight 250 will not start
Hi, David and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch, kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
Peugeot Speedfight 2 not starting up
Scooter Troubleshooting Scooter won start All about Scooters
Peugeot SPEEDFIGHT 100 cc 1998 Parts
PEUGEOT Speedfight 2 Owner Manual
Jul 16, 2017 | Peugeot Motorcycles
Peugeot speedfight wont start
Hi, Michellebym and the usual suspects are:
1. Fuel tank empty.
Peugeot Speedfight 2 Wont start
Peugeot speedfight 2 50cc won start Need help ASAP please
Sep 29, 2017 | 2007 Peugeot Speedfight Motorsport 50
Speedfight 2 runing problem
If it's dying when you let off the throttle, just turn the throttle adjustment screw in a little till it keeps running without your foot on the throttle. I don't know just where this throttle adjustment screw happens to be, but that's what needs done.
Sep 03, 2017 | Cars & Trucks
Please help with my Peugeot speedfight 2 50cc ac
Get it De-Coked. When a 2 stroke runs, it burns the oil and this causes a build up of tar and carbon in the exhaust and around the inside of the combustion chamber. This leads to a decrease in performance especially after the use of a learner. This would also give the white smoke and spluttering. Take it to a bike shop or buy a manual and try it yourself. It is a simple job. Good luck.
Mar 08, 2012 | Peugeot Vivacity 100 T Motorcycles
Electric start doesnt work on moped when i put the keys in and press the break and the button a light on the dash board **** up and it makes a clicking noise but doesnt turn the engine over ??
firstly make sure that the battery is fully charged if it is then its the starter motor thats at fault take the side of with the kick start and behind the clutch system right hand side looking at it there is the starter motor you could try spraying it with wd40 i would use a straw attched to the can as you dont want to get oil on the belt and try starting it again ir that doesnt cure it then the motor is faulty and if you dont ahve the correct equipment for removing the clutch plated you can snap them so i would suggest taking it to a garage/dealer for the repair
hope this helps
John
Aug 12, 2011 | Peugeot Vivacity 4T Motorcycles
New, currently restricted Peugeot Speedfight 3 RS as engine is still been run in. On a downhill stretch, if the displayed speed exceeds about 34 mph the engine very briefly almost sounds like it's...
Hi, Marc your scooter is fine you can discuss your concerns with the technician when you take it in for service.
May 11, 2017 | 2010 Peugeot Speedfight 3 RS
Cycling Logo
408 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
