Question about Yamaha DVR-S150 DVD Player
Not playing NTSC DVDs
The system is kicking off all NTSC DVD`s how can i Unlock it, Because on the manual they indicated that it can play all. is my system locked not to play other region discs? if so how can I unlock it.
  • 4,102 Answers
PLAY: Enter key
STOP: Escape key
Skip+/-: Select root menu
1. Turn off the system
2. Push the "A/B/C/D/E" key with "STANDBY/ON" key pushed simultaneously.
3. Then push "MEMORY" key within 3sec.
4. Front display will now show "DVD DiagMode and few seconds after display [Ver.Disp]
If you push Skip key the display will show [Ver.Disp] or [TV Setup]
5. On the Remote control push DVD/CD key
6. Push "shift" + "8"(A-B) keys simultaneously.
If push Skip key display show [Ver.Disp] or [TV Setup] or [Ver. Matrix]
7. Select [Ver. Matrix] menu and push PLAY key display shows VerMatx>Init
If push Skip key display show VerMatx>Init, VerMatx>
8. Select [Ver. Matrix] menu, Push "shift" + "7"(REPEAT) keys simultaneously.
Now appear VerMatx>Init, VerMatx>U(1),>G(2),>J(2),>K(3),>L(3),>R(3),>A(4),> T(6),F(0)
9. VerMatx>F(0) display and push PLAY key.
10.It will ask "Are you sure?" push PLAY. The unit will now change to region "0"
this should work on your model as others have tried it let me know ok
Posted on Apr 21, 2008
    President:
  • 2,267 Answers
You'll need a One-for-All 6 remote with the code 0539.
Power on the unit and then key in 085. The player’s display should then show a series of dashes. Press 222 222 005 255 and then 'play'
  • Yamaha Master
  • 19,396 Answers
I can see if there is an unlock code for your device
Will the dvp 311ok play ntsc dvd i am in australia and i am reg 4
As long as the NTSC DVDs are not region coded, and your TV is multi-standard (able to receive NTSC as well as PAL signals via A/V inputs or similar connections), the player should play NTSC just fine through it
I assume this is a PHILIPS player? If so, most PHILIPS DVD players support NTSC playback on PAL TV.
You are correct, Australia is region 4 for DVD standard. The only restriction would be region codes.
Feb 27, 2011 | Televison & Video
I just bought this unit and I really like it but it will not play my burned dvd's in color. Why not?
Not seing color is only a matter of PAL & NTSC support by your DVD.
Does it play both original (bought) USA & EU DVDs? Does it play them OK? If yes, there is a color system issue with your DVD - ripping software.
If not (even the bought ones) thens check:
1. Is your TV both PAL & NTSC compatible?
2. Is your DVD player as above?
3. If you are connecting your DVD via another device (a receiver, switcher...) is it supporting both as above?
That's all.
Dec 20, 2010 | Televison & Video
Our new sony dvd player only plays dvd's in black and white. can't find ntsc button on the remote. need help
almost dvds are recorded in Ntsc & please chang your tv color system so you can see the color because through menu you can olny chang the color system for vcd from your dvd player
Apr 17, 2010 | Sony DVP-NS575P DVD Player
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
Won't play ntsf dvds in colour
if your dvd is ntsc compatable then in your dvd settings menu change from Pal to either auto or ntsc also it might be that your tv needs to be changed in the same way
May 28, 2009 | Televison & Video
DVDs all play in Black & White
Could be because it is set to NTSC. Needs to be set to Pal.
Mar 27, 2009 | Panasonic Televison & Video
Certain dvds only play in black and white
is yor dvd play pluged into the tv or is it pluged into a vcr if it is plug it right into the tv.
and are you watching a black and white movie
May 03, 2008 | Televison & Video
Color
It could be a result of wrong broadcast system matching between the player and the TV set.
Press PAL/NTSC button in STOP mode to switch the broadcast system between PAL and NTSC.
Do you have the manual?
Jan 10, 2008 | GPX D1816 DVD Player
Can't get colour when playing back videos and dvd's
Is the picture still or it scrolls? You may be playing NTSC tapes and DVDs on a PAL TV or vice versa. If your TV supports multiple systems, try switching from one system to another (like NTSC from PAL).
Dec 14, 2007 | Sharp DV-NC80 DVD Player/VCR
Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
Sep 21, 2007 | Jwin JD-VD149 DVD Player
Yamaha DVR-S150 DVD Player Logo
197 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
