Question about Orion Televison & Video
I have an orion tv. I went on holidays and turned all power off now I can't get the tv to work
  • Orion Master
  • 19,396 Answers
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...).
The tip was written for projection TV, but basic troubleshooting is the same on your Orion LCD (disconnect to allow PSU capacitors discharge, and test different devices and cables)
As you can read in the article, the basic troubleshooting consists in leaving the TV power cord unplugged for some times, let say one hour or so. Then connect power back with no device connected.
If that does not work, and you keep having the TV in protect mode, that means that there is a fault.
In that case call the support number listed on the TV user manual to arrange repair.
If you are a technician repair is done testing voltages from PSU, diagnostic points and voltages on main controller board, and DC in and high voltage out on inverter. Here a summary description:
How to test an LCD TV .
Faults that may affect an LCD TV after power surges etc (problems that can raise if TV stays connected for long time while on holidays) are inverter, PSU board, main controller board. PSU is most common.
Regards.
Ginko.
Posted on Jul 18, 2010
Orion tv wont turn on after power outage
I would get it serviced. There can be something wrong with it that might not naturally fail.
Nov 03, 2012 | Orion STV2763 27" TV
Orion model 'TV 810 TX'
Possibly a bad power supply. I take it it does happen using the power button on the tv?
Sep 03, 2009 | Televison & Video
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
My orion tv
We had this same problem, and this is what resolved it. Unplug the tv from the wall, wait a minute, plug it back up, and turn it on again with the "power" button. This worked for us (without a remote).
Jun 29, 2008 | Orion STV2763 27" TV
Orion STV2551 27"TV...
The flyback transformer, and some other components may have failed. The main power supply may also be damaged.
It is impossible to know the exact failed parts without trouble shooting the set.
Jerry G.
Apr 14, 2008 | Orion STV2763 27" TV
Orion tv power cord
Try your local radio shack. They may have a universal cord that will work
Apr 09, 2008 | Orion1934 19" TV
Trying to set my Directv remote to control my Orion TV........
Orion code is 11911 and to program your tv to work with a directv remote then follow these...
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Slide the "Mode Switch" back to Directv and try adjusting volume and turning tv and receiver off using the off button and then back on with the on button just above the off button
  • Dec 28, 2007 | Orion1934 19" TV
    Remote code orion tv/vcr # tvcr0950bw
    I have an Orion TV/VCR combo with a Philis Universal remote. I had to use the Sansui codes for the combo. My code for my Orion was 632.
    Dec 06, 2007 | Orion1934 19" TV
    Orion TV 1934
    You might try substituting a new fuse. Be sure the replacement has the same rating. You may have a short in your power supply and depending on the type of supply the supply may not start up if it has overload protection. Stargazer
    Aug 05, 2007 | Orion1934 19" TV
    Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
    Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
    Jul 29, 2007 | Orion1934 19" TV
    Televison & Video Logo
    50 people viewed this question
    Top Orion Televison & Video Experts
    wayne chamberlain
    Jerry Greenberg
    Jerry Greenberg
    Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
