Question about Microsoft Windows XP Professional for PC
The drivers for USB device are not installed. (Code 28)
I HAD CONNECTED A CABLE OF MODEM TO CPU BUT THE USB DEVICE DOES NOT DTECT IT.I HAD TRIED TO INSTALL DRIVERS FROM INSTALLATION DISK N OS DISK ALSO BUT IT DOES NOT WORK. PLS GET ME WITH THE SOLUTION.
    Scholar:
  • 103 Answers
Good Day!
I think the problem is the Driver you are installing, install the driver of the Modem not the usb driver, that is why it was not able to detect the Modem.
Hope I was able to help.
Posted on Jul 18, 2010
This device cannot start. (Code 10)
Did you install the PC Suite properly?...meaning the phone and the cable was not connected to the computer prior to installation. Also, which version of PC Suite do you have?
Jan 14, 2008 | Cell Phones
Pci simple controller comunication not installed .The drivers for this device are not installed. (Code 28)
The "missing" device-drivers could either be:
* a dial-up modem,
* a network-card,
* some serial device, e.g., some USB (Universal _SERIAL_ Bus) hardware.
Access: http://WindowsUpdate.Microsoft.com
Click "Custom" scan
When it completes, click "Optional Hardware",
to see if Windows Update is offering a device-driver.
Jan 23, 2011 | Computers & Internet
Hello, my wireless is not showing on my computer and when i go on device manager on my computer it has a question mark on ethernet controller and say erro code 28, how can i fix this?
Do your Wireless Device (PCI or USB unit) comes with an installation CD? If so, use the CD to install the software/drivers.(Instead of using the Windows wizard). Remove any previous installation before reinstalling with the CD.
Resit your device to a different USB port or PCI slot. If the drivers/software are properly installed, windows will detect and installed the device correctly.
Cause of the Code 28 Error (In general)
A Code 28 error is caused by a missing driver for that particular piece of hardware. There are several of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
1.Restart your computer if you haven't done so already.
There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
2.Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
Undo the change, restart your PC, and then check again for the Code 28 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to the version prior to your update.
•Use System Restore to undo recent Device Manager changes.
3.Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
Important: Make sure you install the drivers for the correct operating system. Example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Most Code 28 errors are caused by updating or install the wrong drivers for a device.
4.Update your OS to latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
**Note: Certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
5.Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. Not recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Hope it helps.
Aug 22, 2010 | Microsoft Windows XP Professional
My Intel Fujitsu Lifebook S series S6240 upgraded to windows 7, but there are some problems. the computer cannot detect devices below and cannot be installed, no matched driver. 1. unknown device, device...
Your device drivers aren't compatible with windows 7. Can you connect to the internet via cable?? If yes run windows update, this should find updated drivers to run with windows 7
Jun 02, 2010 | Intel S6240 Notebook
Siemens adsl modem
If you are using USB connection to connect to the modem, you need the installation disc. If you are using NIC port (network port), you do not need the disc.
May 29, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
I have just brought dell latitude e5500 laptop. i wanted to connected the hp officejet 5610 scanner to my laptop but am not able to do. please help
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab19
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Driver Software for a mobile phone
I have return the phone back to the mobile ph dealer.
Jun 10, 2009 | Cell Phones
Computer not recognizing usb connected nav device
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jun 05, 2009 | Magellan Maestro 3200 GPS
Usb driver for intel 845 GVSR motherboard
u better install windows 7 or updated os in ur system bcoz microsoft had stopped the updates for xp os. so i can say u to install latest updated os to rectify ur problem
Oct 08, 2017 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
99 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
