Question about Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
Fan does not work light goes on and motor noise heard but electrical smell and no blade movement?
    Problem Solver:
  • 10 Answers
Sorry to say this, but if you smell electrical smoke, the fan motor is either dead or soon will be. I recently had one like this, and I immediately replaced the whole fan. It's much cheaper than my fire insurance deductible!
Posted on Aug 15, 2010
Ht38rbu repair noise
Take front of the fan cover off hold the back of fan the push and pull out on fan blades from the center. If blades move in and out .The bearings on motor shaft worn out. If no movement try to blow out the motor with compressed air reassemble then try.
Jul 20, 2014 | Holmes Products Dryers
I have a kenmore elite bottom freezer refrigerator (trio). When the freezer door is closed a rapid clicking/grinding noise has started. When I open the door, it stops. When I close the light switch at the...
I've heard similar refrigerator noises like yours before. Sounds like the evaporator fan motor, located in the freezer and runs only when the door is closed, is being obstructed, possibly by ice, possibly by some wiring or even a food item. You could have a defrost problem, but you dont mention any refrigerator or freezer temperature problem, so that is likely not it. It is also possible the evaporator fan motor itself is out of balance. If you remove the back wall of the freezer, you will be able to see if there is something obstructing the fan blade, if the motor or shaft is out of balance, when you close the door light switch, check the balance of the shaft, it should not have any wobble at all, in fact, if the fan blade is not attached, you should not be able to tell by looking at the motor shaft if the motor is running or not. Also, just happened to think, if one of the fan blades is even partially broken off, that will cause the motor to be out of balance. But if one of these blades is broken, it was broken by something else, either ice or something, and you may have to find the cause of that, otherwise it may happen again.
Nov 09, 2010 | Refrigerators
Vintage emerson electric table fan started making high pitched noise and now the blades will not turn. Even off I can't get them to rotate freely. It has never been serviced or oiled.
The motors on ALL fans have a shaft going thru the motor which turns as a result of the pulsation of AC current.
The shaft is maintained in the center of the motor but alas parts wear out. Metal on metal (the squeaking sound) indicates the parts are wearing.
The stopping (seizing) of the fan blades indicates that any movement of the shaft is no longer possible due to friction.
As repair, a technician could keep the casing and install a new motor.
good luck and don't forget to vote!!!
Sep 29, 2010 | Emerson Dryers
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD Repair technician told me there were problems with the original evaporator motor and replaced it with a new high speed one. Now the fridge is too loud. Before...
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Jan 12, 2010 | Frigidaire FRS26H5AS Side by Side...
Fan blade is not rotating but there is noise
The rotor is stuck and the fan blade will not rotate then a humming noise can be heard. It is due to a bushing problem. It may be stuck due to a hardened accumulated dirt.
  1. Remove the fan blade guard.
  2. Remove the fan blade.
  3. Remove the 4 screws holding the stator assembly.
  4. Pull out the front plate of the motor and the rotor.
  5. Clean the bushing and the rotor.
  6. Lubricate the busing and rotor assembly.
  7. Reassemble in reverse order.
Nov 27, 2009 | Lakewood 16" Stand Fan
My refrigerator has a burnt wire smell. The fans are running but the freezer doesn't seem as cold as it should be.
I'm guessing the condensor fan motor is not running. they smell like an electrical odor when they stop..remove back cover and see if something has gone into the blade area and stopped the motor from turning. if so, remove it ..if not, spin the blade and see if motor starts..if so, order new motor..you can use a floor fan to blow air towards compressor until you get a motor
Bruce
Oct 02, 2009 | Whirlpool Refrigerators
Hampton Bay fan bearing noise
its not the bearings sounds like you need to level the mount and that scraping it the fan blade mounting plate hitting the side of the 'case' that surrounds the motor assembly ive never heard of bearings in the motor going or needing lubrication other than what factory placed in them...remember Hampton Bay is the Yugo of electric appliances too
Aug 03, 2009 | Hampton Bay 24002 Ceiling Fan
Motor can be heard going but the blade wont spin!!
There is usually a pin in the shaft of the motor, that corrosponds with a slot in the fan blades, it sounds to me like either (a) the pin somehow came out, or (b) the slot in the blades is rounded. Hope this helps
Jul 15, 2009 | Patton 20" CVT Performance Air Circulator,...
Fan whining and blades not going
Sounds like your compressor outside is frozen up or (locked up) the smell is outside correct? it could also be your fan also in your condensor unit outside the easiest way is to listen for fluid movement (if your freon is moving then your compressor is working and you need to lean toward a fan motor. check to see if you can move the fan blades in the compressor (outside ) if the problem is in the house then approach in the same way with the power to the unit turned off only If you cannot turn it most likely fan motor replacement is in order, and pressure sensors are not letting your condensor run. theres a few things to try hope i have helped .Honestly it probably would not hurt to let a service man look at it anyway, but this way at least you're a little wiser chris
Jun 12, 2009 | Goodman CLT36AER36 Air Conditioner
Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan Logo
109 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
