Question about Nokia N900 Smartphone
Opening/closing the keyboard slider often switches the phone off
My n900 phone was exposed to some water after which it started to often switch off when shook or when the keyboard slider is open or closed, even if done so slowly.. the back side (e.g. the battery and sim card space was completely dry ). the phone however also does not always instantly recharge from the regular charger. this happened just 2 days ago so i am not sure whether this is a time to dry issue or i need to get it to the service center.I would appreciate some advice. thank you...
  • 524 Answers
Hi,....
This may be because there may some water log present inside it which is preventing from charging and making it to often switch off by shorting some lines when current is passed through it.
NEVER charge your mobile when it get wet.even though it works well after drying there may be some water log which may cause the circuits to short and even cause shock to the person using it.
please give to the service centre they wil remove the water logs in it and the phone wil properly after that.
thanx
Posted on Jul 18, 2010
My nokia n900 fn is locked. how to unlocked?
Hi, You can unlock your Nokia N900 safer and easier using unlock code. You can get the unlock code from www.onlinegsmunlock.com/nokia-n900/rs7wp9/ at affordable cost .
Here are the steps for unlocking a Nokia N900,
1 - Switch on your Nokia N900 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N900.
3 - Compose #pw+CODE+1#.
4 - The Nokia N900 would then display the message "SIM Restriction Off" and will be unlocked!
Sep 08, 2012 | Nokia N900 Smartphone
N900 camera showing black screen
Please switch on the camera, if you have enough charge on the camera.. or else charge it.. Even after switching on the camera, if it is black, then screen might got have damaged.. Service it if you have warranty..
Apr 01, 2012 | Nokia N900 Smartphone
How to unlock n900 from us to philippines
It simple to unlock the Phone from Network lock,you can get the Unlock code from the site
www.classicunlocking.com and UNLOCK it, you can follow the instructions below and unlock it step by step...
Nokia N900 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia N900 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N900 mobile phone, your phone may get hard locked and sometimes become unusable.
Note :For Nokia N900 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N900
Oct 13, 2011 | Nokia N900 Smartphone
Hi, my nokia n900 will not boot. When i try to switch it on the nokia logo appears then it switches off and the same the things happens over and over until I switch it off. Can you help?
hi...
if the phone is in warranty then goto the service center and update software.
if problems remains same then change the strip of the mobile from nokia service center.
Feb 01, 2011 | Nokia N900 Smartphone
The problem with my nokia n900 is when the battery finsh and the phone turn off icant charge my phone nokia n900 can you help mee plzzzzz
Remove and re-install the battery. Keep the phone switched off and connect the charger. Wait a few minutes before you attempt to switch it on again. If this does not work, your battery is fried due to deep discharge and needs to be replaced.
Update the Maemo 5 operating software on your phone, the current release removes a lot of software problems, including the charge blockade in low battery situation.
Dec 13, 2010 | Nokia N900 Smartphone
The moonroof on my 2002 lincoln towncar is stuck open. I can hear the motor when I push the open button, but the motor sounds dead when I try to push the button to close. Could it be jammed? Is there a...
Temporary Fix: unsnap off the access door in the overhead ceiling liner behind the sunroof opening;
Use a 4mm hexagon Allen wrench to wind it closed.
Sep 12, 2009 | 1999 Lincoln Town Car
My locks keep opening and closing on their own
Sounds like u have water in the switches, Water is a conductor of electricity and will bypass the on, off switch, Need to dry it and see if that helps.
Aug 16, 2009 | 2006 Chevrolet Cobalt
Just water pump start
Check the water supplies at the back, if the valve is opening, and the water is getting into the machine, it can be a faulty water level switch, or membrane sensor, depending on the model.
A faulty or clogged inlet valve can also close few seconds from opening the valve, usually becausu of a faulty solenoid.
If valve and water level switch are ok, then this is a faulty control.
Have valve and water level switch checked first.
Dec 10, 2008 | Whirlpool AWM6120 Front Load Washer
Nokia N900  Smartphone Logo
212 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
