Question about HP LaserJet 1320 Printer
When printing I get a "thicker" run blob line ( on the left side of the paper) no mater if I print word or excel. I have changed print cart. Any help?
  • 122 Answers
Thi is certainly due to a piece of paper stuck in the paper path, or it needs the cleaning wire on the underside of the toner cartridge sliding back and forth to clear it. Take the cartridge out, and you will see a wire that goes the full length and it will have a plastic lug attached to it. Slide this back and forth a few times then refit it.
My first reaction is that there is a small piece of debris in the path that will cause this problem. Have a good luck inside. Unplug the printer before you do this :-).. Good luck
Posted on Jul 18, 2010
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
My HP 1320 prints a thick black line down the left side of each page of a document.
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Jul 27, 2009 | Office Equipment & Supplies
A black line is printing on the left side of the
Pull out the toner cartidge, lift the flap and look at the drum, it should be clean. you will have to buy a new cart to fix
Jun 03, 2009 | HP LaserJet 1300 Printer
Lexmark X5320 won't print acts like it's printing but paper is blamk, also tells me right ink is wrong( it is not)
Hello there,
The most common cause for printing blank pages is (1) Failure to remove the protective tape from the bottom of the cartridge. Even if you have removed the tape, there might be some residual tape left at the bottom of the cartridge. I would suggest you check out for this yellow or/and transparent blue tape at the bottom.Please remove it, if present. (2) If there is no tape left behind, then the next option is to clean the cartridge nozzles. I would suggest you go to Lexmark control program or Lexmark Solution Center and run the clean nozzle test. You should see solid dark lines on the print out. Repeat the process 2-3 times till you get a good output. (3) If all the above steps fails, don't worry.. we have one last thing to try... Remove the carts from the printer.. take a warm damp paper towel Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge. Repeat this process atleast two times and then put the carts back to the printer after 1 min (we need to allow the cart contacts to dry). Now you can install the cart to the printer and try printing. If you still have a problem with the cart, then I would suggest you try another cart as there should be something wrong with the cart that you have right now.
Merry Christmas!
Dec 21, 2008 | Lexmark Office Equipment & Supplies
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
HP 1020 printing problems
It seems like the problem is not the printer, but your Excel file.
Jul 27, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1320 Printer Logo
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
