Question about Motorola Mobility RAZR V3
My Razr Screen Turns White After like a couple seconds. The inside screen is white the outside screen turns blue. Itll work for a couple seconds then it messes up. whats wrong?
    President:
  • 1,561 Answers
I think the problem with your phone is that, the flex on the screen of your phone is malfunctioning and will need to be replace.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Posted on Jul 18, 2010
My phone always turns off. and the screen always turn white. but when it goes back to normal, the screen has no cracks. but after a couple of seconds, it turns white again
water damage. If you have a young child or dropped it on the bathroom floor after showering or even outside humidity can do that. Heat is also another thing that can do it. Or simply just dropping it.
Jun 13, 2009 | Motorola Mobility RAZR V3x Cellular Phone
White screen
take the phone and have the lcd replaced on the phone from a mobile service center
Nov 08, 2008 | Motorola Mobility RAZR V3
My Razor Front screen wont work
you will need to replace the LCD on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
White screen
tarheelfan,mtstreaks88 ...try changing the flex cable in the phone if that does not work, replace the LCD or Screen as you call it.
Dec 15, 2007 | Motorola Mobility RAZR V3
Motorola Razr front screen blue, inside screen white/blank
this i did find a guide to opening the moto up .
http://themotoguide.com/razrdisassembly.php
hope this helps you out.
riz.
Nov 12, 2007 | Motorola Mobility RAZR V3c Cellular Phone
White screen on Motorola RAZR
I use to work for Cingular Wireless and this happened often. Try opening and closing the handset a little forcefully. It should re-seat the screen onto the contacts. If that doesnt help, have it replaced since its new. Best of Luck.
Sep 05, 2007 | Motorola Mobility RAZR V3c Cellular Phone
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
Blank screen
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
White Screen
change your settings
Aug 25, 2007 | Motorola Mobility RAZR V3
White Screen on Razr, What is a "Strip Problem"
Before you open it and look inside it check to see if the magnetic switch is stuck. Check it with a kitchen magnet to the upper righthand corner of the keypad. There is a magnet in the lower righthand corner to activate it. Do some of the function work when it is closed? If they do then it is not the cable but the switch. Does the outside screen look the same as if it is closed then it is this switch? Could be a bad one, something stuck in there, or it could be stuck.
May 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
