Question about Car Audio & Video
Car battery has been diconected ,therefore I need the code to get it working again. It is in a Hyundai excel 1997 model. cheers , steve.
  • 3,230 Answers
Well you can get this code from the Hyundai dealer or check the user manual comes with your car. If you can't able to get the code from any of above then please follow the link below -
http://www.radio-code.com/HyundiaPayPageRadiocode.htm
(Just copy and past the above link in your web browser and follow the steps)
Good Luck!!
Thanks
Posted on Jul 18, 2010
Hyundai excel 1997 wont start
Recheck your work,don't guess or assume anything
Any parts or wires that came off, may not be back where
they need to be
Otherwise you check for crank signal,injector pulse,fuel
pressure,spark,the usual players
Mar 11, 2014 | Cars & Trucks
How to remove the code for the cd radio for a Porche boxter 1997
hello there
try to diconect the battery and the radio should flash CODE after you reconnect the battery
proporsche
Jan 28, 2011 | 1997 Porsche Boxster
The belt on the airconditioner in the hyundai excel 1997 is making a squealing noise it seems to be coming from the tension pulley
it could be that the bearing in the tensioner has run dry of lubricant,it may be possible to take it off & grease it,some you can & some you cant so it may have to be replaced.......hope this helps.....cheers
Aug 09, 2010 | 1990 Hyundai Excel
Petrol filter on Hyundai excel glx
hi,the petrol filter on a excel is on the firewall right next to the brake booster! it is black in colour --cheers
May 17, 2009 | 1994 Hyundai Excel
1997 Hyundai Excel will not start- started and ran well yesterday
hi--have the timing belt checked-- just remove the cover on the left side of the motor or #1 end and turn it over to inspect the belt--cheers
May 04, 2009 | 1994 Hyundai Excel
Hyundai 1993 Excel 1.3 litre injected ,travels a few hundred Kilometres and stops only to go again a half hour later. Check Eng Light comes on. Cheers, Laurie.
it's an ecu related problem .. a component in the ecu is overheating and has to be replaced .. possibly a transistor in the power input area
Feb 20, 2009 | Hyundai Motor 1993 Excel
Radio code for 1997 Hyundai Excel. Factory supplied radio.
if you have the owners log books for the car look to see if the code is in there
if you do not have it then you need to get the model and chassis number from the top of the unit
then you need to go to Hyundai and they will get the code number and they will give it to you
i think you are better off going and getting a new cd player and having that installed
hope that helps
ricko
Dec 01, 2008 | 1994 Hyundai Excel
Radio code for 1997 excel
CONTACT HYUNDAI OR YOUR LOCAL DEALER THEY CAN SUPPLY THE CODE WITH PROPER OWNER INFO.RICHARDM69
Paint code for blue hyundai accent pony 1998
try this:
Hyundai Paint Color Code Location:
[1997-Present models]
  • Usually found: Driver side door Jamb (6).
  • Other place to look: inside engine bay area by Firewall (middle) (3), or Radiator Support (front middle) (10) , or Under Driver Seat (5).
    [Before 1997 models]
  • Usually found at: Driver side door jam (6).
  • Other places to look: Firewall (middle) (3) (Excel) (Scoope), or Radiator Support (front middle) (Sonata) (10).
  • Click here for diagram Paint Color Code Looks Like:
  • They are usually shown as a two digit number on the vehicle, such as PV or E8 .
  • Click Here for Hyundai Paint Color Code Label Sample
    Sep 13, 2008 | Hyundai Accent Cars & Trucks
    I just changed battery and then i found i couldn't use radio anymore. The window show "code" everytime i tried to turn on radio. My car is 1995 Hyundai excel.
    You need to re-insert radio code . If your radio is factory provided you may ask code from local hyundai dealer.
    Give radio model number to search if can be found also on web.
    Aug 06, 2008 | 1994 Hyundai Excel
    Car Audio & Video Logo
    32 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
