I want to se the user guide for the monitor mv540
  • 30 Answers
You can download the product manual in a PDF file from the following link...
Posted on Apr 21, 2008
En el monitor aparece un candado azul en condicion de cerrado y despues se abre pero no se quita
"Bloqueo OSD: Controla el acceso del usuario a los ajustes. Cuando '' (+) es seleccionada, no se permiten ajustes de usuario. Todos los botones están bloqueados excepto el botón de menú.
Todos los botones se puede bloquear o desbloquear cuando el botón "Menú" se empuja y se mantuvo durante más de 15 segundos.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 17, 2011 | Dell E153FP 15" LCD Monitor
I have found that this tip worked for my Compaq MV540 - press the diamind button...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Jun 09, 2008 | Sony SDM-HS73P 17" LCD Monitor
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
Jan 22, 2010 | Compaq MV 540 15" CRT Monitor
User guide for phone SE 330
get it from google .. type se 330 user guide.. that should work :)
Aug 01, 2009 | Lands Phones
CRT Monitor Stuck In Stand-By
So the monitor is not bad try to disable the video card from bios if possible and firstly remove all external devices (USB's) and gets the safemode meny and select vga mode and disablem the video drivers and uninstall and reinstall the drivers
Jul 01, 2009 | Compaq MV 540 15" CRT Monitor
Compaq mv540 monitor does not come on when i turn the computer on. the green on line turns orange
in a technical language you can say its a display problem. the monitor is fine.its actually the problem inside the pc.either some connections are loose or the ram memory needs to be cleaned or some part is gone faulty which needs to be checked.if any of this happens the display wont come.check all the above possibilities to reach the cause and solve the problem. please do rate the solution,thanks.
Jun 12, 2009 | Compaq MV 520 Monitor
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
Brightness control+blurrness of images+
no can do. you monitor is dead in the water.
lost of focus, and intensty. all point to one thing.
by the way, do you have the correct video driver installed???
Jul 01, 2008 | Compaq MV 540 15" CRT Monitor
Doesn't respond
Compaq MV 540 (old dog monitors) DEAD 100% DEAD.
OSD dead too. it seems.
built in year 2000, its 17 years old, and you fix things that old
why> why do that, used LCD can be had for 20 bucks.
why slave over any relic CRT like this,,, for a musiem??
using the VGA cable
the monitor will go to sleep, lacking any PC sync lines Vert/horz
by design per VESA rules on that !
step one , use a PC.
set the PC up to do the max resolution on the CRT
some PC cant do that, (new PC)
im reading your users guide now, 1sec, google , hit.
first force the PC to 1024x768 resolution and 60 vert. refresh max.
now the CRT can work an not any of above number higher .
see? use working monitor to do that FIRST.
now plug in the vga,cable last. on the monitor under test.
power led means
green = power ok
amber or yellow are sleep or standby.
so that means, there is no sync.
or if the OSD works (does it>) turn the silly sleep timer off in the monitor. via OSD .
the operators guide, tells you to go to PC safe mode.
this mode sets reso real low. 800x600 and all monitors work there.
no sleep timer inside monitor i can find.,
lots of ways for any CRT to fail even the CRT itself
(loss of sweep)
loss of cathode video drive
the VGA card inside, can fail. killing dead all cathod drive.
the power supplies or regs inside can fail.
the HV can fail. 10,000 volts (dont touch it if long life is good)
some survive, or fly back hit head on wall and crush skull,
seen it and done it so,,, there you go.(ripped gash in arm once)
the 2nd anode is very high voltage, avoid it, and win,.
respect it.
Sep 20, 2017 | Compaq MV 540 15" CRT Monitor
Getting my speakers to work
with PC it's in the back with the "Sound" or ear phone icon sticker.
May 13, 2008 | Audio Players & Recorders
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
