Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
External hard drive "Fantom titanium II" "I/O Device Error"
External hard drive, Fantom titanium II error "I/O device Error" I can't open the device it stops my computer from loading anything without a 'not responding' white shaded program. I can not use chkdsk on it and I have not found a forum or Idea's that help. So I am here now can somebody help?
and thank you for your time and attention.
Paul
  • 5 Answers
SOURCE: I/O error FDU80
Dear Enryc2 I don't know if you have found a solution already but this is what I tried. If this is your bootup drive, disconnect all other drives, eg., CDRom/DvDRW, FDD, USB drives and try to bootup. You may also try to update your BIOS(only if you know how to).
Posted on May 01, 2007
  • 23 Answers
SOURCE: Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Posted on Jan 21, 2008
  • 26 Answers
SOURCE: my pc and mac computer do not recorgnise my fantom drives
Hi, Mac uses a certain file system that windows does recognize the best thing i would suggest is mount it back to you mac and copy all the date to your mac then format the hard disk with windows ntfs files system. now u will be able to use it on both.
Cheers
Posted on Apr 27, 2009
Crankstart
  • 696 Answers
SOURCE: server can't detect USB hard drive
Hello, Assuming you're running windows 200 or newer, no drivers required. If it is not detecting in device manager the shell is likely damaged and simply needs to be replaced. If it does show up, and the drive does not the the drive is likely damaged and you will most likely require professional help recovering the files. If the latter is the case please state you location(country and city) and I will recommend an appropriate facility to assist you. Chris
Posted on Jun 05, 2009
SOURCE: how does a external USB SATA drive dock
The Solution: ... IT WORKS REALLY ...
Point 1: Remove power from the mains.
Item 2: The device from your PC, remove the USB plug.
Point 3: The USB Titanium External Hard Disc Enclosure Open, just the screws of the housing, with a special wrench to open.
The drive from the connector of the USB connector for one minute to remove, then the hard drive with the connector of the USB connection,
connect together.
Point 3: The hard disk into the housing insert all the screws screw.
PLEASE precisely again check that all connections are properly connected.
Power to the drive plug the USB connector from the HDD to the PC or notebook is already running and the hard drive, as before, during initial installation of the device.
So everything supper dooper easy ...
Posted on Jun 27, 2009
I am using Fantom Titanium 250GB External (TFDU25072B) Hard Drive i am not able to formate it i am using Windows XP Sp2 its giving me error " unable to formate " even i am not able to formate it...
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Fantom's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
Oct 30, 2010 | Fantom Titanium 250GB External...
I have Fantom Drives Titanium 250GB i am not able
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
I have a Fantom Drives Titanium II 500GB external drive that cannot be seen by my computer. I receive the error USB Device is Not Recognized. I've tried it on a different computer with the same problem. ...
It's all about the drivers. Just go to the manufacture's website, go to download or support tab, download the drivers. Then once they are downloaded, double-click on the file so it installs itself into your pc, then restart pc and you should be good to go.
Jul 23, 2010 | Computers & Internet
I can not locate a driver for my Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive. Do you know where?
Your device should not need drivers Fte Fantom/Titanium drives are fully supported by both Windows and Mac OS's.
Try replacing the cable or using a different USB port.
Sorry I cannot be of more help, The drive itself may be damaged, You can test this by physically removing the drive itself from the case and installing it internally to your system....If the drive functions properly, then the problem is within the board inside the casing.
Ed
Jun 08, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
My pc and mac computer do not recorgnise my fantom drives
Cheers
Apr 27, 2009 | Fantom Titanium Hard Drive
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
170 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
