Question about Sony Playstation 3 (PS3) Console
How do you set up a ps3? - Sony Playstation 3 (PS3) Console
    Genius:
  • 1,478 Answers
I would suggest you follow these procedures, hook up your PlayStation 3 to a television. You must decide whether your TV supports high definitions (HD) resolution or not. For HD resolution, you must use a HDMI cable or a component video cable. These cables also support standard definition (SD) resolution. If you only have an SD television, you can use an S-video cable or an AV cable. These two can't support HD resolution.
Connect the PlayStation 3 to any audio equipment such as a A/V receiver or home entertainment system. Connect using a digital audio cable or, alternatively, run an HDMI cable to your A/V receiver then another HDMI cable to the television set.
Plug in the Ethernet cable, then connect the other end to a 10Base T jack from your home network. This connects you to the Internet and the world of online gaming.
Attach the AC power cord to the PlayStation 3, and then plug it into a surge protected wall outlet. Don't plug in the power cord until all other connections have been made as a chance of shock exists.
Perform the initial set up of the system. Turn on the power of the TV and game console, and follow the on-screen prompts. The pre-installed software guides you through the set up process.
Take care.
Posted on Jul 18, 2010
My ps3 is set to 1080i but when i play need for speed undercover it plays in 480p
Open the PS3 - selected - the display Settings - video output Settings - choose TV interface for Hdmi - automatically
If this is not good, he connected HDMI line, and then hold down the PS3 power key 5 seconds. The PS3 will reset the display Settings. Select the default best resolution oh •
If you want to have better ps3 controller, here are cheap ps3 controllers
Dec 23, 2012 | EA - Electronic Arts Sony Ps3 Game Need...
Problem with the Sony Playstation 3 (PS3) Console PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Try changing your DNS settings on the PS3 or on the router
Changing the DNS on your router: Go to 192.168.1.1 Default password is: admin Static DNS1: 208.67.222.222 Static DNS2: 208.67.220.220
Those DNS setting are from OpenDNS
After doing this, reconnect your PS3 to the router and set it to Automatically adjust the settings. Once you have reconnected, check if you are still having the DNS problem.
If you are still experiencing the problem, try changing the DNS directly from the PS3 Go to Internet Connection Settings and set everything to Auto except DNS When asked if you should set the DNS automatically, choose "Manual" Input the same DNS settings: Static DNS1: 208.67.222.222 Static DNS2: 208.67.220.220
Apr 09, 2011 | Sony Playstation 3 (PS3) Console
I plugged my PS3 into one TV and after changing the setting to SCART I tried to plut it into another TV and it will not load up
When you're switching to a new or another TV other than the one that you're using you will need to reset the video settings on the PS3.
To do this turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings so you will be able to set the video settings again on the other TV and access the PS3 menu to set it up.
Regards.
Aug 16, 2010 | Sony Playstation 3 (PS3) Console
How do i reset my ps3
To reset the PS3 to factory setting, do the following:
  • On the PS3 Menu go to Settings > System Settings > Restore PS3™ System and click yes.
This will have fully restored your PS3.
Oct 29, 2009 | Sony PlayStation® 3 (60 GB) Console
Desire to transfer all game information from PS3 40 to PS3 80. PS3 80 has information on hardrive that I would like to delete first so I can set up with new I.D. etc. from PS3 40. Then after the PS3 40...
Go to Settings, System Settings, Back Up Utility.
You'll have to hook up an external usb drive with a good amount of space.
Use the backup utility.
Swap the 40gb drive with the 80gb drive.
Follow the onscreen PS3 prompts. A message will possibly pop telling you that you need to download a firmware file etc. If it does download the latest PS3 firmware from here:
http://www.us.playstation.com/support/systemupdates/ps3
You'll need to have it installed on a folder on your external drive like this:
PS3-->UPDATE-->firmware file
The playstation will look for the file once you press the SELECT and START buttons at the same time on your ps3 controller.
Follow the prompts, it should be straightforward.
After everything is done.
Go back into Settings, System Settings, Back Up Utility.
Click Restore and then follow the prompts.
Boom you're back in business.
Let me know if you have any other problems and check out my PS3 blog here for tips and other info:
http://www.rescuetechla.blogspot.com
Thanks!
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
PS3 HDMI Audio Problem
The settings on your PS3 may be to high for your TV. try turning off your PS3 and turning it back on, when you turn it on hold the power button untill it beeps aprox 10 sec. this will reset the your PS3 back to original (minimum settings)
Aug 14, 2008 | Sony Playstation 3 (PS3) Console
My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Sony Playstation 3 (PS3) Console Logo
98 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
