Question about Dryers
Dryer Squeaking I have a Maytag MDE9606AYW Electric Dryer. It squeaks when I first turn it on.
  • 4,102 Answers
the problem could be one of a few things the first is the belt tension might need adjusting or the belt might even need replacing this is the cheap and easy solution.
the other is expensive and difficult this is the drum bearing this needs specail tools to replace but this is not likely the problem.
Remove back cover and check belt tension it shouldnt be to loose but also not over tight check the belt for crack and replace if damaged. You can tighten the tension with metal bar and spanners but youll see this yourself.
Also the noise could just be a general noise that you might get just due to wear and tear so if the belt is fine then i wouldnt worry to much if it was drum bearing then it would be more of a constant sound happening all the time.
Let me know if you need further assistance ok
Posted on Apr 21, 2008
    Scholar:
  • 178 Answers
A couple of possibilities, your belt could be getting worn or the dryer motor pulley is slipping causing it to squeak. if you send me an e-mail to robert_fawbush@yahoo.com , I will be able to send you pictures of your dryer to make it easier for you to troubleshoot and do the repairs on your own. Major money saver.
Dryer making squeaking noise, what causes this?
The squeaking could be coming from the idler pulley on the motor, the drum rollers or a worn drum seal. It is not a good idea to spray the rollers with WD-40. The WD-40 will attract lint that will build up and could catch on fire inside the dryer cabinet. A bad drum support roller or any other squeaking component inside a dryer cabinet will normally need to be replaced.
Aug 29, 2011 | Maytag Neptune MDE6700A Electric Dryer
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer, 25 year old dryer has a loud squeak
Hello.
The squeaking is coming from the rollers that the drum rides on. If you take the model number to a local appliance service store they will have the parts and be able to direct you on replacing them.
Jul 20, 2009 | Maytag PYE2300AY Electric Dryer
Gradual squeaking increase
Check the drum's roller bearings - they sometimes look like large rollerblade wheels. The may need to be replaced. They are relatively inexpensive, and can usually be found at your local appliance parts store.
Too, check for a  felt "ring" around the front of drum (if applicable). Again, if too worn, replace it.
Jul 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Mar 23, 2009 | Maytag PYE2300AY Electric Dryer
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Dryer Squeaking noise when first turning it on
nedd to replace the rear tub rollers
Apr 21, 2008 | Dryers
Dryers Logo
315 people viewed this question
Top Dryers Experts
