Question about Creda W100FW Front Load Washer
Door hinge how to fit door hinge on cread w100fw
Firstly if you haven't already done so remove the door and the old Hinge. You can do this by undoing the screws at the back that hold the top of the machine on and remove the top of machine. Now you will see a piece on the inside where the hinge screws into. Hold onto this piece and undo the screws from the outside. Carefully remove the inside piece (because I dropped mine inside and it took me an age to get it out!!). Now undo the screws on the door and pull it apart. Replace the old hinge and screw door back together. Now holding the inside piece back in original position screw the hinge and back onto the machine. (You might need someone to hold the door in place for you....it makes it much easier). Finally screw the top of the machine back on.
Posted on Jun 06, 2008
Change side of door opening
Remove the door by unscrewing the top hinge and lifting off. Remove bottom hinge. Using what was top hinge, fit to bottom of opposite side. Fit door on with "top" hinge and secure.
Apr 26, 2012 | Refrigerators
How to unlock the hinge on an Ariston Oven Door with door off
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
May 17, 2010 | Ovens
Best way to fit saloon door hinges . how to set out the job before fitting saloon door hinges
Set the bottom height first and make sure the two are level ... then fit the door ... allow for the up and down movement required by the bottom hinge.
Mar 24, 2010 | Drills
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
Water not draining from the drum and no filter in evidence
Remove rear panel of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Thanks.
Aug 15, 2009 | Creda W100FW Front Load Washer
Door lock broke and machine not start
You need to fit a new door lock.
Remove front of door seal, and fit new door lock.
Jul 20, 2008 | Creda W100FW Front Load Washer
Door Hinge replacment
my door indicator light wont stop flashing the door is locked
Mar 05, 2008 | Creda W100FW Front Load Washer
Washing machine door hinge
I cant find much on this unit. the back can be remove but will likely not help you .
remove the top access panel ,
remove the front control switch panel.
then you can remove the whole front door and all.
its really not that hard just be careful of the plastic items.
Feb 27, 2008 | Creda W100FW Front Load Washer
Creda simplicity 1000 door hinge
I had the same problem and got a new one on ebay
Nov 30, 2007 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
138 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
