Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Refrigerator is cold, freezer not freezing
Coils were not cleaned on schedule.  Now they are very clean but no freezing in freezer at 7 setting.  Can compressor be replaced? Refrigerator is working fine at 5 setting.
  • Amana Master
  • 1,606 Answers
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Posted on Jul 18, 2010
ARB2214CW freezer not cold Set At coldest over night no change to temp.
It could be to cold , sometimes the Freon coils will freeze and that will make it not be as cold so turn the freezer down all the way or un plug for a day or so to let those coils defrost then turn it up again.
Dec 17, 2011 | Amana ARB2217CSR Bottom Freezer...
MY FREEZER IS NOT FREEZING ANYMORE ONLY SITS AT ABOUT ZERO DEGREES. FRIDGE PART WORKS FINE SO FAR BUT RUNS LONG. CAN THIS BE FIXED. WE HAVE THE SETTING IN FREEZER SET AT 7 OR THE HIGHEST SETTING.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Refrigerators
GFreezer is cold, suddenly won't freeze
Hi, make sure the evap coil and the condensor coils are clean. make sure there is no ice build up on the evaporator located in the back of the freezer. It could also be a bad t-stat or low on refrigerant. Call a tech if it still does not work after you clean and make sure that both coils are clean and ice free.
May 19, 2011 | Amana ARB224RCC Bottom Freezer...
Top Freezer has lost it's freezing power. It's set on the highest level 7 and doesn't freeze the food... also there is a clicking sound every 5 minutes or so... this has started since Wednesday since we...
heatman101
Apr 30, 2011 | Maytag Refrigerators
Model # FRT18IL6DWP Moisture droplets on top of freezer - not freezing at normal setting - turn to coldest setting and freezes but moisture droplets still forming but freezing - model is 4 years old Model...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 27, 2010 | Frigidaire FRT22TSE
My freezer is cold but not freezing the refrigerater is cold also but not as cold as normal.what could be going on cleaned coils already.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 11, 2010 | LG Bottom Freezer Refrigerator w/ Swing...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
937 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
