Question about Pioneer AVH-P4000DVD Monitor
I have a pioneer avh-p4000dvd. The volume knob turns but wont turn the sound up and down. Is there anyway u can help?
CosmaP
  • 409 Answers
SOURCE: CHANGE REGION 1 TO 2 FOR AVH-P4000DVD
Kali Mera, Ti Kanis?
I have been looking in to this, but there does not seem to be a hack available.
http://www.videohelp.com/dvdhacks?dvdplayer=AVH-P4000DVD&hits=50
Signomi
Posted on Oct 24, 2008
  • 253 Answers
SOURCE: how to unlock the eject button on a pioneer avh-p4000dvd
remove ur eject option from menu bar and for tchnician help contact http://tinyurl.com/mtgjzz
Posted on Jun 22, 2009
  • 24 Answers
SOURCE: bypass without switch
Get a relay (4 or 5 pin) from Autozone, O-Reilly, PEP Boys, etc....
Connect wires as follows on relay:
Pin #86 - Amp remote from your radio (blue wire)
Pin #30 and #85 - to a chassis ground (metal dash bracket)
Pin #87 - to Parking brake input wire on your radio (light green)
Pin # 87a - IGNORE. It isn't used in this case.
What this will do is.....
Radio will power on when you turn your key. The amp wire is delayed slightly and will trigger the relay in a second or two. This tricks the radio into thinking your e-brake has been engaged and violla....Mine has worked everyday since I connected it.
Posted on Jun 26, 2009
SOURCE: No videp playback on Pioneer AVH-P4000DVD only getting sound !!!
To all who do the bypass on the AVH-P4000DVD and whenever they turn it on and put a dvd and bypass the screen and hear audio but no video I got the solution for it, Here is what to do:
Unplug you harness and next to the black wire in the harness should be empty. All you have to do it hook up an extra wire in the empty spot (again right next to the black on harness) and then connect this new wire to the ground of the car harness. So basically take the ground from the harness along with the ground from the car along with the new wire you installed along with the switch ground and pingo it shuold work. I just did this and it worked.
Enjoy it.
Posted on Aug 08, 2009
  • 24 Answers
SOURCE: bypass for pioneer AVH-P4000DVD so i can watch
Here is a diagram...
Posted on Aug 10, 2009
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
I need a avh-p4000dvd wiring diagram
i have the manual for it .. i hope this helps -- ther are phone numbers to call Pioneer to get further information
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVH-P4000DVD_OperationManual0123.pdf
Oct 30, 2010 | Pioneer AVH-P4000DVD Monitor
I have a pioneer avh-p4000dvd everything works just the display is off it would sometimes flicker on and off but wont come back on
there is a reset button on the left of the cd player. u will need a needle to hit the button. once u hit it, the screen will still say caution but when you touch the screen it will go back to your regular settings
Feb 24, 2010 | Pioneer AVH-P4000DVD Monitor
Avh-p400dvd---cannot get it off of demo and eject lock
hole the volume mute button in for a few seconds and it will turn off
Dec 26, 2009 | Pioneer AVH-P4000DVD Monitor
Pioneer AVH-P4000DVD video goes black after 2 or 3 seconds. I can touch screen and it comes back but for only a couple of seconds. Audio is fine
You pressed the Disp. Off button on the bottom left corner. If you press it again it will stop turning the display off.
Oct 25, 2009 | Pioneer AVH-P4000DVD Monitor
How to unlock the eject button on a pioneer avh-p4000dvd
Jun 22, 2009 | Pioneer AVH-P4000DVD Monitor
THE SCREEN WONT TURN ON
it might be hooked up so that you have to have the parking brake on while you play dvds or you might have to turn your dimmer all the way down for it to play while driving. does it play the audio and everything when you put a dvd in but wont displau if so then that is your problem.
May 05, 2009 | Car Audio & Video
What's the recommended camera for avh-p4000dvd pioneer unit
Pioneer recommends Pioneer ND-BC2, but you should be able to use any with a descent viewing angle and RCA connections.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Watch a dvd while driving pioneer AVH-P4000 DVD
ground the wire to a hot (ie power comes to the wire) switch in your dash, like a rear window defroster or seat heater. turn the switch on then off and it will trick the system into thinking you activated the parking brake.
Mar 03, 2009 | Pioneer AVH-P4000DVD Monitor
Signomi
Oct 24, 2008 | Pioneer AVH-P4000DVD Monitor
Pioneer AVH-P4000DVD Monitor Logo
60 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
