Question about Honda Pressure Washer PSI 3000
The engine runs wide open at start the throttle will not adjust and acts as if not connected just flops around but I can not find and loose wires or bolts
  • 41 Answers
Its a spring! Under the fuel tank there is a link that goes from your carb to your govenor. Replace the spring by taking off the fuel tank, romove breahter and filter assembly, and then your carb. From there you can easily remove and replace broken spring. Take caution when removing the carb so that to dont damage the gaskets!
Posted on Jul 23, 2010
Craftsman DLT 2000 with Briggs and Stratton 25 HP. Engine runs at wide open throttle.
What is the float set at? What about the jets and fuel screw? Do you know what the fuel pressure is?
Aug 26, 2016 | Craftsman Garden
Reduce engine power 2003 gmc Yukon xl.....replaced
First check ALL fuses,,,,make sure there good,, then check,Computer or wiring to the computer,,,sometimes where the wiring harness conects togeather they will break or loose connection,,or back out of the connector,,,,feel the wire just behind the connectors see if its broke, or loose or backed out of the connetor,,,very time comsuming ,,also the loom going to the throttle body,, check for naked wires touching around/ going to throttle body
Sep 14, 2014 | Cars & Trucks
I need help with my B/S Engine. Lack of power and black smoke coming from the exhaust.
If the plugs are ok and your engine is not smoking after starting and running ..Sounds like either of three things..all with the carburetor .First the carb has a adjustment screw for air/gas mixture on the side if the carb where it attaches to the engine..try this start the engine and at about half throttle..now adjust the screw clockwise until the engine starts to miss and bogg down then back the other way until it starts missing and bogging again. Then slowly adjust back and forth until you hear the engine run the smoothest..give it more throttle if it starts to run rough do the same procedure until you get the results you want..if it is the mixture problem this will take care of it..if this doesn't it it may be your fuel jet in the bowl dirty or the blow float sticking..if you are not familiar with carbs best to have a professional look at it..you can drop the bowl by removing the bottom bowl and clean it out...check to see if the float easly moves up and down..replace the bowl and go from there..worse scenario new or rebuilt carb...good luck..
Jun 07, 2014 | Briggs & Stratton Garden
I change the distribuator cap,rotor, and spark plug wires on my 1983 ford ranger 2.3 engine now when its warm the engine runs wide open can you tell me why it does that?
you may have a leak in the intake manifold which is acting like the throttle being open-look for a crack or loose bolts on the manifold to the head- cheers Denny
Dec 07, 2013 | 1983 Ford Ranger
It runs wide open all the time im wondering where idler arm setting is at
It sounds like the govenor spring has become disconnected or the clamp on the governor shaft has become loose and allowed the linkage to get out of adjustment. If problem has occurred suddenly it could mean the governor gear assembly inside the engine has broken and means the engine will need to be dismantrel to replace the governor gear assembly.
Check throttle linkage to see if spring is attached at both ends, one end on the throttle linkage and the other at the fixed point on the engine or to the end of the speed control lever. With engine stopped the spring should hold the throttle wide open and hand pressure on the linkage shoud be all that is needed to move throttle shaft closed to the idle position with no binding in the movement of the linkage.
If spring is OK and while engine is running, linkage should be able to be be moved to bring engine back to idle. If porblem has occurred gradually, then linkage will need re-adjusting. Loosen adjusting clamp on governor shaft, then holding linkage in wide open throttle position rotate shaft as far as it will go in the opposite direction to that requred to close throttle to idle . Re-tighten clamp.
Dec 11, 2010 | Coleman Powermate Premium Plus 6250W...
24horse vtwin runs good at half throttle seems to lack power.turn on the mower deck and sometimes it runs ok but will not mow normal lenth grass not much power.if i turn the throttle up wide open it will...
Sounds like you're getting enough fuel (black smoke) Could be running on only one cylinder. Either stuck valve or loose valve adjustment or one bad magneto. You could try starting with one spark plug disconnected. If it doesn't start, reconnect that one and disconnect the other. IF it runs like it was, then you're running only one cylinder, and go to work on finding out why.
Aug 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
1991 Ford E-250 5.8L My code reader states the throttle control voltage may be either too high or too low. What controls the voltage and what should the voltage be when attempting to start the engine. I...
Hello! The Throttle Positioning Sensor (TPS) is defective...It is bolted to the throttle body...It is a round black device about the size of a 1/2 dollar, with a mounting hole on each side...It has a 3 wire connector...Wire colors are...Gray/White...Gray/Red...And Brown/White...Cost $55...Use 2 safety pins...Push the pointed end into the rear of the connector on the Gray/White wire and the other on the Gray/Red wire...Do not disconnect the connector...Set a volt meter to read a maximum of 5 volts...Place the + probe on the Gray/White wire...The - probe on the Gray/Red...Turn the key to on...Voltage must be less then 1 volt (.85)...If not TPS is defective...
Do not move probes...Start the engine (if you can)...Watch the meter...Slowly increase the throttle...Voltage must rise to 4 volts (wide open throttle)...As voltage rises...If the voltage skips, jumps, or acts erratic the TPS is defective...
Guru...............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jul 15, 2010 | Ford E-250 Cars & Trucks
Engine will not run wide open
you need to make sure there is not a fuel restriction first check the fuel filter, then the lines. If these seem ok then adjust the High speed rpm, there should be two adjusters one for High speed one for low speed(when the throttle is fully engaged.Do small adjustments at a time.
Jun 14, 2009 | Garden
Honda 1300c backfire through carb at wide open throttle. I have open up the exhust and rejetted the carb . the bike will run fine up to mid throttle or 65 mph but if you accellerate hard or go to wide open...
Try balancing ans syncronising the carbs.
BALANCE THE CARBS
Turn the throttle screw on the LEFT carb one half turn inward. Now start the engine and get it warmed up. With the engine running, remove the RIGHT spark plug wire. Adjust the idle speed on the left carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Now turn the throttle screw on the RIGHT carb one half turn inward. Restart and rev the engine. Next, remove the LEFT spark plug wire. Adjust the idle speed on the right carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Turn the idle screw on each carb EXACTLY ONE QUARTER turn outward and restart the engine. The engine will be probably be idling very fast. Adjust both the idle screws equally from this point to get to the desired idle speed.
SYNCHRONIZE THE CARBS
Remove the air filter and rubber fittings to allow you to see into the throat of both carbs. You may need a mirror to see inside. You need to be able to see the slides go up and down when you twist the throttle. Now turn the fitting where the cable goes into each carb such that there is just a bit of slack in the cable, 1/16" is plenty. Lock ONE of the cable adjusters down tight. All further adjustments will be made on the other carb.
With the motor turned off twist the throttle very slowly while looking at the slides. Both slides need to begin lifting at the exact same moment. If the slides don't raise at the exact same time then slowly twist the throttle until the locked adjuster slide just barely starts to move. Hold the throttle still and turn the adjuster on the other carb so that the slide on that carb just barely starts to move also. Now recheck the slide movement timing. Do this process until the slides on both carbs begin to raise at the EXACT same moment. Lock down the loose adjuster and re-check the slides.
Please rate this solution. Thanks!
Mar 30, 2009 | 2004 Honda VTX 1300
Honda Pressure Washer PSI 3000 Logo
341 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
