How to convert an 8 wire to a 5 wire thermostat
  • 43,501 Answers
Even if you can do that it is way beyong the scope of what could be translated toyou through this media...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
I want to hook up a new Honeywell thermostat that has 8 wires in place of an old mercury one that had 5 wires
You just need to used that 5 wires. The rest you leave blank. Your new thermostat has stage 2 heat and cooling also 1 for reversing valve which you don't need.
Jan 06, 2018 | Honeywell Heating & Cooling
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
I AM NOT GETTING FIRE TO THE #8 AND #5 PLUG WIRE ON A 1964 283 SMALL BLOCK THAT HAS BEEN CONVERTED TO ELECTRONIC IGNITION
Are you checking at the Dist Cap or spark plug end of plug wire ?
If you are checking at the plug end of wire try exchanging that wire with a working wire. If the problem is not there with other good wire the wire must be bad. If it is not the plug wires to #8 & #5 replace DIST CAP. The Cap must be cracked or arcing internally.
Oct 16, 2013 | Garden
4.7l V-8---error code P0308 is being displayed---about a year ago, I replaced the plugs and all 8 coil packs---thanks
Hi. This P0308 code means that the the PCM has detected that one of the engine's cylinders are not firing properly. In this case it will be cylinder Number 8.
A code P0308 may indicate that one or more of the following has occurred:
1 Faulty spark plug or wire
2 Faulty coil (pack)
3 Faulty oxygen sensor(s)
4 Faulty fuel injector
5 Burned exhaust valve
6 Faulty catalytic converter(s)
7 Running out of fuel
8 Poor compression
9 Defective computer
If there are no symptoms, the first thing to do is to reset the code, with a code reader, and see if it comes back. If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the affected cylinder and plug/coil assembly. Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs-COP-). In some cases, the catalytic converter has collapsed. If you smell rotten eggs in the exhaust, your converter may need to be replaced. I've also been told several times that the problem in this case could be a faulty injector at that cylinder 8.
Sep 04, 2010 | 2004 Dodge Ram 1500
I need a spark plug wire diagram for 1987 ford 302 crown vic
1987 Ford Crown Victoria 5.0L FI 8cyl
Duraspark Type Plug Wires
The spark plug wires used with the Duraspark type ignition system are 5 / 16 in. (8mm) in diameter to contain the higher output voltage. There are two types of wires used in this system, and some engines may have both types installed. It is important to properly identify the type of wire used for each cylinder before replacements are made.
Both types are blue in color and have silicone jacketing. The insulation material underneath the jacketing on some plug wires is a silicone layer separated by glass braid. The plug cable not incorporating the silicone layer is used where engine temperatures are cooler and are identified with the letter SE with black printing. The plug cables with the silicone insulation are used where high engine temperatures are present. These cables are identified with the letters SS with white printing.
Each spark plug cable, if original, is marked with the cylinder number, model year and date of cable manufacture (quarter and year). Service replacement wires will not have cylinder numbers, or manufacture date.
On any vehicle equipped with a catalytic converter, never allow the engine to run for more than 30 seconds with a spark plug wire disconnected. Unburned fuel in the cylinder may ignite in the converter as it is exhausted and damage the converter.
When removing spark plug wires, mark and tag the individual wires. Grasp, then slowly, twist the insulator back and forth on the spark plug to free the insulator. Do not pull on the wire directly as it may become separated from the connector inside the insulator. Special tools are available which can help ease plug wire removal, and prevent damage to a cable.
When installing a new set of spark plug wires, replace the wires one at a time so there will be no confusion. Start by replacing the longest wire first. Route the wire exactly the same as the original.
Fig. 1: 6 cylinder engine-240Firing Order: 1-5-3-6-2-4Distributor Rotation: Clockwise
Fig. 2: 8 cylinder engine-255, 302, 351, 400Firing Order: 1-5-4-2-6-3-7-8Distributor Rotation: Counterclockwise
Fig. 3: 8 cylinder engine-390, 427, 429, 460Firing Order: 1-3-7-2-6-5-4-8 DistributorRotation: Counterclockwise
Visit autozone.com (free register) for more details.
I hope helped (rememer rated this) Good luck.
Oct 15, 2009 | 1987 Ford Crown Victoria
Hi I am replacing a trane thermostat it has 8
call hunter fan co. you will have to jump out some term.
Jul 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Want to replace manual thermostat with programmable.
you can use a 5 wire heat pump thermostat.
Must be heatpump thermostat
red is 24 volt power
white is aux/emergency heat these usually will need to be jumped together
Green is fan
yellow is compressor contactor
blue is reversing valve
you just don't have a common so some thermostats will not work.
get one with batteries
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Switching from air conditioner to a haier heat pump
(only the control wires from the thermostat to the inside and outside unit.A regular airconditioner has a 4--5 wires control and a heat pump has 7--8 wires control..!
Jun 02, 2008 | Haier hwr10xc6 Air Conditioner
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
