I am having problems setting up my Manhattan SD313E scanner to scan comic book barcodes
Corster
  • 79 Answers
SOURCE: problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Posted on Jan 03, 2008
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
SOURCE: DS6708 symbol scanner freezes keyboard
Have you tried taking the battery out of the scanner and then reinserting it? THis should reset the scanner to some degree.
It really depends which barcodes you scanned in the manual.
Your best chance seems to be a reset to the original settings, for which you may need to look at the manual.
Posted on Mar 18, 2008
SOURCE: it3800 barcode scanner problems
Will it scan data into excel or word?
Posted on Aug 05, 2008
SOURCE: The scanner is scanning but no data is transmitted to the PC
I also purchased a Symbol LS4071 and when I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector - the connector is split like a "Y") I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Posted on Mar 23, 2009
Need barcode list for SG303
if you don't have the device application software download it from your cd driver that come with your device and locate the setting of the scanner in the configuration area you will find where you can initialization
Jan 14, 2014 | Manhattan Computers & Internet
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
When using the scanner to scan books in a library setting I have to push the enter button on the keyboard after I scan the book. Is there a setting so you do not have to hit the enter button; it will just...
Hallo Jason,
yes, this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document.
https://docs.symbol.com/attachments/ADC-01244.doc
Sep 15, 2010 | Symbol LS2208 Handheld
THE RED LINE THAT SCANS BARCODES MOVES RAPIDLY UP AND DOWN HOW DO I CHANGE IT BACK TO THE SETTING THAT THE LINE IS STILL
Do you have the programming book? It will have barcodes that are scanned to program the scanner.
Apr 08, 2010 | Symbol LS 4278 Barcode Scanner
MS9535 BT Bluetooth Wireless Barcode Scanner Problem
Problem with Scanner settings .you have to load default setting to scanner from Configuration guide which comes with Scanner.
First Scan the Enter /Exit Configuration then select load defaults and at last scan Enter/Exit Configuartion.
Scanner will be o.k
Jul 07, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Scanner doesn't scan all barcodes
these scanners are user configurable, to prevent scanning of an inappropriate barcode, only the required barcode schema are enabled, if you look in your code book you will find that there is a page with listings and examples of the various different barcode schemes, in the section before that there should be a list of barcodes that allow you to program the device to use whichever barcode scheme you wish (as long as it is compatible with the scanner)
so you can enable the scanner to read 128, code 39 or EAN and also you can configure prefixes / suffixes depending on your software's requirements
Oct 10, 2008 | Falcon 4420
Two extra digits at beginning
you can use the code book to clear any prefixes that may have been set on the scanner or you can try a factory reset (using the code book)
Sep 03, 2008 | Symbol LS2208 Handheld
Decodeing UPC-A Supplemental 2 or 5 code
you should have a code book that came with the scanner, the code book allows you to program the scanner's options, the code book takes you step by step through the programming proccess. each option requires you to scan varios barcodes to "set" the various options one of the options will be to set the barcodes you wish to use, this is set to avoid a misread (confusion between barcode standards)
Aug 07, 2007 | Symbol LS 4000i Handheld
Computers & Internet Logo
457 people viewed this question
David Payne
David Payne
