Question about EliteGroup ECS RS480-M (1.0) W/1394 AMD K8 SOCKET939 MATX RETAIL Motherboard
I have a rs480 motherboard that I need the manual for so that I can repair or connect my speaker into the proper position.
  • 6,487 Answers
You can download the user manual for this motherboard from this link.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=506&CategoryID=1&MenuID=47&LanID=9
Posted on Jul 18, 2010
Looking for manual for rs480m motherboard
Try this one:
http://productsmanuals.com/computer-manuals/ecs-rs480-m-motherboard-manual
Feb 16, 2012 | FIC AU13 Chameleon Motherboard
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
Nosound
The problem may be of many reasons. Some of them are : - Bad cable - Speaker not working properly - speaker not connected properly - Driver problem
Check that you have properly connected your speakers to your computer and also check for any cuts or bruises in the cable. Connect your speakers to any other device such as your phone or pmp to check whether the speaker is working. You must also update your sound drivers to the latest version. If the problem still persists you may have to get your motherboard repaired.
Mar 01, 2011 | Intel Motherboard
I NEED DRAWING FOR THE FRONT PANEL CONNECTION
Download the manual for you're MSI PM8M-V motherboard from MSI; http://www.msi.com/index.php?func=searchresult&keywords=PM8M-V&table=download
You will need to download and install Adobe reader to view the manual. Download Adobe; http://www.adobe.com/products/reader/
Open manual to page 9. See Front Panel Connectors: JFP1 & JFP2. There is no need to connect JFP2's Power LED jumper, this is completed at JFP1. Each wire jumper coming from the case will have one wire color in common with all connectors except the speaker jumper. That common colored wire will be use as negative.
The speaker wire commonly as red is positive and black is negative.
Cheers'
Mike
Apr 22, 2010 | MSI PM8M-V Motherboard
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Jan 11, 2009 | MSI K8MM-V Motherboard
Hdd led off
see to the front panel section on mother board possibly on the right hand side of bottom u can see the label there to connect hdd led
Dec 28, 2008 | MSI RS480M-IL (816909008517) Motherboard
No audio output
some BIOS options allow the disabling of on-board audio. did you check the BIOS setup screens?
Sep 03, 2007 | EliteGroup RS480-M (RS480MV10) Motherboard
Computers & Internet Logo
35 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
