Question about HP PSC 2355 All-In-One InkJet Printer
BIJ 2800 unable to print as error "-00D4-c3f9 LIB MICCI.DL212" error appears
-when on printer there is a prompt "turn on or off the printer. -00D4-C3F9 LIB MICCI.D:212" error appears.
- change power cord and point but still unable to print.
- unable to press any control panel key as it does not respond..
- changed the supply station, Formatter and Ink Supplies status but still same problem.
  • 25 Answers
HP All-in-One Products - Performing a Partial Reset of the All-in-One Introduction There are times when a partial reset may be required to restore the all-in-one to proper operation. A partial reset does the following:
  • Reset the user settings to the factory defaults.
  • Reset the language and country/region settings on some models.
Performing a partial reset Follow the steps below to perform a partial reset of the all-in-one:
  1. Unplug the power cord from the all-in-one.
  2. In the table below, locate the button combination for your model.
      NOTE: If your all-in-one model is not listed in the table, your model does not have a partial reset option.
  3. Press and hold the button combination for your all-in-one.
  4. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
Product family/model
Button press
HP PSC 2500 series
Press and hold # and 3 while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+ ) instead of # .
Posted on Jul 08, 2008
In my printer page pro 1500w when they printing i off printer when i on error came?
Konica Minolta Customer Phone Number Shortest Wait Best Support
Call Us
6361 2800
Opening hours
Monday to Friday 10:00-12:00 / 13:00-17:30
  • Phone Number
    800-456-5664
  • Talk to a Human
    Press 0 OR Press 1, then 3 and then 1 then wait for the prompts
Dec 08, 2014 | Office Equipment & Supplies
HP7180 ERROR OXC18A0401 INK SYSTEM HAS FAILED UNABLE TO COPY RECEIVED FAXES OR PRINT CAN YOU HELP ME? RO
Without turning off the printer, disconnect the USB cable at the back of it.
Remove the cartridges and wait for the 'Insert Cartridges ' message to display on the control panel.
Disconnect the power cord from the back of the printer then wait 60 seconds and reconnect the power cord.
If the printer does not automatically turn on, press the Power button.
Reinsert the cartridges, and then close the cartridge door.
If it prompt you to print a calibration page, do so.
Reconnect the USB cable at the back of the printer, and then try printing again.
If the same error message appears on the front panel service your printer.
TNX
Apr 23, 2011 | HP Photosmart C7180 All-In-One InkJet...
How do you retreive faxes in the memory of a brother intell 2800
The intliFax 2800 has 2 types of memory.
If you have enabled the Fax Storage option (menu 2 5 2) then you can either turn this option off and you will be prompted to print or you can press Menu 2 5 4.
If there are faxes in the emergency memory, they should print once you clear the error message, if not, then press Menu 2 6 which will attempt to print out any jobs in memory as well.
Thanks,
Pat
Apr 08, 2010 | Brother IntelliFAX 2800 Laser Fax
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
Jun 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error E000733-0001
There is a poor contact between the DC control PCB and main controol PCB .
to clear this error press * 28 * and select copier &select function & select clear and press OK
((*)means additional function button on display).
Jul 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Unable to init error message and and machine error 4f
i can not print any documents it keeps coming up as Init unable 4f please help ?
Sep 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to use duplex printing on LaserJet 1020
Do you have Status Messages turned off? Access the Printer Properties window. Click the Configure tab (figure 1). Re-enable Status Messages by selecting On . Power cycle the printer by turning it off, then back on. Wait a few seconds for the job to resume or try printing the job again. Here is the hp link : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00383419&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en Good Luck
Mar 08, 2007 | HP LaserJet 1020 Printer
HP PSC 2355 All-In-One InkJet Printer Logo
597 people viewed this question
Ben Johnson
