Question about Broderbund American Greetings Creatacard Platinum 8 for PC
CreataCard Gold6 does not work with Windows 7 CD 1 and 2 do not work
  • 12,061 Answers
Try setting in compatibility Mode, for XP SP2, and run the main .exe, as administrator, that may help.
Posted on Jul 18, 2010
    Problem Solver:
  • 5 Answers
Ok after days of working with this on windows 7 32 bit. I have found that having anything pluged into the speaker jacks make it crash. with the error. you that are having problem try and unplug your speakers and see if it wor
Posted on Sep 10, 2010
Micrografx creatacard 3 gold - repeat only micrografx, not american greetings
Micrografx Creatacard Gold 3 was created back in the Windows 98 days and most likely the installer is a 16-bit installer. Windows XP worked OK with 16-bit installers, but Vista, Windows 7 and Windows 8, 8.1 will not work. There is a work-around I found ( I actually found this fix for installing Photoshop 7 under Windows 7) and it works! I was able to install Photoshop 7.0.1 under Windows 7 Pro x64 edition and it works great!
Perform a search for Install-Photoshop-6-or-7-on-Windows-7 or go to this website http://www.wikihow.com/Install-Photoshop-6-or-7-on-Windows-7. Under this website, Look at Method 3 of 3 .
Stuff you will need:
1. A working Windows XP -SP3 system where you can install the Free Scalable Smart Package. You may be asking why? You will need to install the Micrografx Creatacard Gold 3 on this system with the "Discovery Program" running so it can create a new 32-bit installer
2. A CD-RW or a Memory Stick where you can copy the new .MSI file created and run it from Windows 7 x86 or x64 bit system.
3. Download the Free Scalable SmartPackager program. This used to be called WinInstall LE but they have since changed the name. You can find the program here http://www.scalable.com/smart-packager-ce-msi-package/. This is Free, but you still need to register to get the software. The latest version as of last week is v2.0.2.
4. Printed out instructions from the website so you can follow along. Once you perform this, you may end up trying this for other "older" software as well.
Basic Overview:
1. Under your Windows XP - SP3 system, install the Packaging software called Scalable SmartPackager v2.0.2
2. Once you have installed the SmartPackage program, it is a good idea to Reboot your system so all files get updated properly.
3. Start the icon called Smart Packager.
4. Under Smart Package, make sure you are under the Welcome screen and click on the Discover a new Package under Common Tasks.
5. When the Blue Discovery screen pops up, click on the Next button
6. Under the New Package Information screen, type out Creatacard Gold3 or something that you like
7. Under the Output Folder, Click the Browse button and select a folder or location where you want the new Creatacard Gold3.msi to be saved. Make sure you click on the Show advanced Options box below and Then Click Next
8. On this screen, you will now need to Click on the Start Discovery. This is what the SmartInstaller program will use to see where all the files are being installed to, etc when you run the Creatacard Gold 3 installer.
9. Insert the Micrografx Creatacard Gold 3 CD in the drive and install the program like you normally would. Please remember to install any of the Extra Free fonts as well during this time since this will be the only time you will have to create a new 32-bit installer (unless you run this process again)
10. After the Creatacard Gold 3 program has installed, verify it is working by Running the program and testing out various things within the program. (This is while the Discovery is still running in the background)
11. Once you have verified the Creatacard Gold 3 program is running properly (under the Windows XP system) then go back to the Discovery window and click on the Red Stop Discovery button and then click on the Next Button.
12. Make sure the Add new package to Smart Packager is checked and then click on the Finish button. This will now save the new "updated installer" MSI file over to the folder location you specified under option 7 above.
13. Copy this new *.MSI file you just created and either burn it to a CD-RW or copy to a Flash drive and take this file over to your Windows 7 system.
Please note, these instructions are an overview and may not contain the entire correct order. The last time I performed this was back in January 2014 when I first discovered the article about using Scalable Smart Packager to re-create an installer file into a true 32-bit installer.
For me so far, the installer has worked with Photoshop 7 and several Photshop plugins like KPT5, KPT7, etc.
I make no guarantees that this will work in your situation but it could not Hurt.
Plus, should you have problems removing this program I would recommend you try this Free program called Revo Uninstaller v1.95. This is Free for Home/Personal use only.
Hopefully you can use the above instructions I provided and get this great program to work under Windows 7.
Please let us know if this process worked for you or not.
Nov 23, 2013 | Broderbund American Greetings Creatacard...
I have Almerican Greetings CreataCard Plus 3 application cd, but will not work with windows 7, I have a many years of work done with creatacard on hard drive and am not able to access it. I need to get at...
go to" www.amerciangreetings.com" and go to support, you should be able to get the updated progrma that will run on win 7 your software is out of date
Feb 21, 2011 | Computers & Internet
Is there a Creatacard CD compatible for Windows 7?
Creatacard cannot be run under Windows 7 because of compatibility issues. You have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 05, 2010 | Broderbund American Greetings Creatacard...
I have creatacard gold 4 that will not load with windows7 onto a new HP Pavilion computer. I tried the compatabiliy modes and still it will not load . the trouble shooting program says that it is...
Dear,
Your HP computer may be new, but your programs must be compatible with your operating system. If your Creatacard is older, the compatibility most likely stops with Windows Vista. Windows 7 is like a "brand new day". Read the label on your CD. It will tell you which systems it will work on. I had Windows 98 and Windows Millenium. When I upgraded to Windows XP my "create" CD's no longer worked.
Try downloading Avery cards. Be blessed.
Mar 13, 2010 | Broderbund American Greetings Creatacard...
Problems w/American Greeting Creatacard Plus on 64 bit Compaq computer w/Windows 7. Are there any drivers or anything that will make this computer work on this new system.
Windows 7 shares alot of the atributes of windows Vista,try that driver.
System Requirements
  • Platform: Windows 98 / XP / Me / 2000
  • Media: CD-ROM
  • Item Quantity: 1
See more system requirements Product Features
  • Windows 98/2000/Me; 200 MHz Pentium or compatible; 64 MB RAM; Windows XP; 300 MHz Pentium processor or faster 128 MB RAM; Minimum 427 MB hard disk space; 800x600 display, 16-bit color;
  • Windows compatible mouse; Windows compatible sound card and speakers; Windows compatible printer (monochrome or color); Microsoft Internet Explorer 5.0 or higher
  • 33.6 Kbps modem or faster and Internet service provider account required for Internet access, online graphics, online projects, and animated greetings
  • Encore/ RiverDeep
  • PC
This is system requirements "above" Vista and Win 7 are not supported.You would have to contact them for support.Sorry.
Jan 23, 2010 | Broderbund American Greetings Creatacard...
My Creatacard Gold does not work with Windows 7. It worked with Vista and Windows XP.
my creatacard gold c.d dose not work on my new laptop which is window 7 can you help
Dec 08, 2009 | Broderbund American Greetings Creatacard...
My OS is Windows Vista Home Premium. I have Am. Greetigs CreataCard Platinum 7. Does this not work with my OS? It seems to be "preparing for installation" a long time with no luck to run the program....
Start the "Windows Compatibility Wizard".
Select that you want to install a "Windows XP Application".
Point to the CD-ROM containing the software.
Install it by selecting the 'setup.exe' file.
Nov 14, 2009 | Broderbund American Greetings CreataCard...
Creatacard 3
i hate Vista as well. i am trying to find a solution. my whole life over the past couple of years is wrapped up in the eventminder and fmnot32 files but after installing Creatacard on my machine with Vista, it will not recognize the files.
i open my address book, it's empty. i open my calendar it too is empty. how can i get this program to recognize the files i copied from the old machine? PLEASE HELP! i've tried everything including dragging them both over at the same time (file plus .BAK). i don't know what else to do.
Apr 23, 2008 | Broderbund American Greeting CreataCard...
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
448 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
