Riso GR3750 T1 error Drum Jam
I have a drum stuck in the machine with a T1 error message. I saw the latest post on this problem but cannot located the latch/hook the gentleman speaks of. I service manual is in route, but need to get this running asap. Any help? Thanks
The hook is located just above the power supply once the back cover is off. Also there is a drum release centered under the drum that a screwdriver can disengage.
Posted on Apr 22, 2008
  • thesavage5 Oct 07, 2010
    Thankyou Magahi! That was VERY helpful!!!! My GR3750 is now FIXED!!!
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Colour Drum Stuck
Underneath the drum, in the front, is a little
Apr 10, 2014 | Riso RZ220 Duplicator
I have a Riso GR 3750 and have a T 2 and T1 error and can not pull out the drum (we don't get a green light) we also tried shutting down while holding the reset button to no avail. when we accidentally...
The syncronicity of feeding mechanism and drum is lost. The sound was the jumping of the toothed belt.
Seems that the stripping finger or the blower is stuck in the clamp mechanism blocking the drum moving forward. This problem can be caused by a worn rubber reel. So the stripping finger is not lifted enough any more.
Remove the back cover. Locate and check the rubber reel running at the excenter of the print drum. Do not turn the machine in forward direction till this is solved. Else you may damage the clamp mechanism.
To restore synchronicity you have to remove tension of the toothed belt by loosening the 3 screws around the paper feed clutch. Turn the mechanism clockwise and fix a screw temporarily in this position. Now it should be easy to lift the toothed belt over a tooth, moving a bit, and so on. You have to move the drum driving mechanism till the sensor there meets the small hole. At this position the sensor at the paper feed mechanism should match the cutted semi-circle. Synchronicity restored. Restore tension at thoothed belt and test.
Apr 13, 2011 | Riso RZ220 Duplicator
The riso is indicating that there is a jam in the drum area. I am getting a message A-01 -211
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
Dec 21, 2010 | Riso RZ220 Duplicator
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Riso gr 3770
check sensor (photo) that point towards the drum from inside and clean use a flash light to locate good luck
Dec 02, 2008 | Office Equipment & Supplies
I had this problem too: just unlock the hook under the drum; disengage the drum then pull out the drum; then check the home position if not in position open the behind cover, pull the belt until you get the puller to the home position. You will get the same problem if you will not put the main drum puller to the home position. chimuntu@yahoo.com
Aug 06, 2008 | Office Equipment & Supplies
Error Code
From memory (haven't looked at one for about 7 years) the T1 fault was when the latch hadn't disengaged.
Back panel off, towards the middle at the bottom there is a small solenoid with a kindof latch/hook. It will be engaged onto a small lever.
IF it is the same fault as above, it's really easy to sort, by pushing it off with a screwdriver, as a lever.
The way to tell is if the roller under the drum is still engaged. If so, you won't be able to pull out the drum.
Let me know if it helps, or if you want another suggestion.
Feb 14, 2008 | Riso RZ220 Duplicator
401 people viewed this question
jasbo
jasbo
