Question about Vizio VX37L Television
How do I fix my blue screen on my vizio tv - Vizio VX37L Television
Vizio VO370M LCD TV screen is mostly black with green/blue horizontal stripes at the to. How can I fix this?
Most likely you are looking at a defective LCD panel, but I would recommend getting a proper diagnosis.
Sep 07, 2012 | Vizio VO370M LCD TV
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
I have a 19" vizio
LCD TVs are made of many tiny light bulbs. In your case a row of them went out. i believe u can get this fixed if you take it somewhere.
May 06, 2011 | Vizio M190MV 19 in LCD TV
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
Vizio VX37L Television Logo
685 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
