Not sure how to get power and ground - Audio Players & Recorders
  • kevinpatton4 Jul 18, 2010
    I didnt get a chance to put all info. so solution was not useable but response should be
  • 2,272 Answers
To what other source the unit is connected.whats is the model number.what is the brand of unit.explain the problem in bit more detail.so it can be helped in much better way. please keep updated.Thanks.
Posted on Jul 18, 2010
    HI
    Its a plmca30 going on a 2004 Kawasaki Vulcan 1500. I have a connector but no connector on the bike if I split the connector I dont know how and where to connect them.
    Thanks, Kevin
  • raj somaiya
    raj somaiya Jul 18, 2010
    You can tie the power into the license plate light line. The Hardest part is finding a place to mount the amp on bike. you will have to get handlebar clamps separate from this kit to mount them.
    Thanks.
I have a DOD Mixer console, model 1642. It is giving me a 60 cycle hum. When I turn on the board all of the LED light max out. I have turned it on and off a couple of times to see if I can get it to...
I had this problem when I was attaching a "custom" power supply (an ATX power supply) to my DOD 1642 (circa 1992, revived in April 2012). I had a massive buzz and every LED was totally lit up. The problem ended up being a grounding issue.
If you're using the stock power supply, make sure the ground is attached firmly both at the three-prong connector at the wall as well as the 7-DIN connector on the back of the board. You may want to take an OHM meter and make sure the grounding pins are all in contact throughout the power supply: With everything unplugged from wall power and the board, test from either (or both) of the DIN pins to the ground prong of power plug (on the adapter NOT THE WALL). Then, test for connectivity between the two grounding pins.
If you're using a custom power supply like me, make sure you're grounding to a proper and valid ground. I ended up attaching my ground to three of the ATX grounding pins and the hum went away. My 20 year old mixer is alive and well now.
Feb 13, 2011 | Audio Players & Recorders
My 2001 isuzu rodeo battery is not charging. alternator is good, battery is good. HELP please
STEP1:Replace the terminals(make sure the wires are NOT corroded power and ground by removing some of the wire insulator)if they are corrodeSTEP2:Replace power and ground wires and make sure your chasis ground(body ground)is clean,once clean make sure you TIGHTEN IT.
Jan 22, 2011 | 2001 Isuzu Rodeo
My amp keeps blowing its fuses whenits plugged in
Go over all your wiring. Make sure your power wire isn't grounded somewhere. If your power wire is touching any bare metal it will spark and blow the fuse the second you touch the power to your amp. Make sure your in-line fuse is about a foot from your battery, and make sure you have your ground wire grounded securely to the main chassis of the car/truck and that it is either same size gauge as your power or even a little bit bigger gauge. Also make sure no strands of wire from your ground or power wire are loose and reaching over touching the other where you plug them into the amp. If the ground and power touch eachother they will blow the fuse and possibly cause permanent damage to the amp.
Jan 06, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Do you pull a ground to your new generator or just use a ground rod
Hello, an interesting question. I am not sure what your local codes state, for myself to prevent any ground currents, I would pull a #6 ground as a minimum and not install a ground post. Like I mentioned above, your local codes may or may not require a post. Be sure that you connect the ground from the generator securely to the existing ground in your existing ground system.
joe
Jan 06, 2011 | Generac Power Systems Generac 5525 20 Kw...
My monitor is shivering due to magnetic field tell me solution
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
Dec 08, 2010 | Gateway HD2201 22" LCD Monitor
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
Car audio, power wire problem...
75% of the time all you need to do is reground the ground wire. If you don't have a sturdy ground it can't complete the circuit. Make sure to grind off the paint so you're grounding to bare metal. Also, make sure your ground wire is the same gauge as the power wire or larger than. That should do it.
Jan 25, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Amp pulses
make sure our ground is good thanks pierre
Jul 17, 2008 | Pioneer GM-5100T Car Audio Amplifier
Wiring
You need to wire the ground wire first, because this will make sure that the amplifier doesn't blow when you connect power. Your power cable comes last. First do the ground, then remote and follow with the power. Make sure the ground is attached to the body of the car properly, otherwise you will get poor sound
Jun 04, 2008 | Jensen XA2150 Car Audio Amplifier
Amp
Make sure the amplifier is turning on. Remember ther is three wires that power the amp Battery constant, Ground which in a fiberglass boat run ground to battery not motor, Plus make sure the remote wire is hooked to power, generally it is switched power. But if the amp is not turning on temporarily hook remote and power together to battery and see if the amplifier turs on. Second be sure you have a good set of RCA cables hooking the radio to the amp. And finally check and make sure the gain is turned up on the amplifier.
Aug 31, 2006 | Dual 2-Channel Bridgeable MOSFET Amplifier...
16 people viewed this question
 Grubhead
Grubhead
