Question about Kenmore Elite 45986 Front Load Washer
Ordering CCU for kenmore elite 45986
Yes, I've removed the CCU for the kenmore elite 45986 front load washer - i find a number AAWCB-003 on the inside - is that what i order by and i'm in Houston (Katy) TX trying to find the part. Thanks in advance!!
  • 5,911 Answers
Are you attempting to replace the Main Computer Microprocessor, or the User Interface? The Main Computer is located inside the washer behind the wash tub, while the User Interface is behind the control panel. The term CCU sometimes gets used interchangeably and I need to be sure.
It's easier to order parts directly from searspartsdirect.com. Just type in your model number (located around the door opening) and you will find both of the parts I mentioned under the "Control Panel" heading. If you wish to try a local Sears dealer in your area, you can use the part numbers provided by the Sears website.
I hope this helps you. Please post back if you need further assistance.
PS If you wish to compare pricing, you can also try repairclinic.com. Both sites get their parts from the same part source. They both offer comparible pricing with one or the other often having better deals.
Posted on Apr 21, 2008
    Problem Solver:
  • 14 Answers
The CCU board sometimes does not have the part number on it . You need to have Your washer brand name specifically the model number when placing you order. Make sure you describe the location of the part you are about to replace. Sometimes The operators have a diagram/picture of the part location in order to confirm the right Part you are ordering. I hope this is of any assistance. Good luck
Posted on Feb 09, 2013
I have the F06 error code on my he4t washer. I've checked online with all of these "fix it" sites and had an electrician check the motor. All of the connections and the motor are fine. How...
The MCU is the motor control unit its in the lower panel down on the bottom
The CCU is the central control unit and it is up in the top behind the touchpad/cycle selector
Sep 23, 2011 | Kenmore Elite 45986 Front Load Washer
What does the f11 code on a kenmore elite he3 washer mean
A bad CCU (main control circuit board) will cause this F11 problem 90% of the time
Aug 26, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
Manual for kenmore elite 45986 front load washer
See the following site and select your actual model number:
The 45986 number is the stock number, not the model.
http://www.managemylife.com/mmh/owner_manuals/search?query=elite+45986
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite went through a cycle, but didn't spin on the final rinse. diplay screen is flashing F then H. F then H. what is going on?
The F/H code means the unit isn’t detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I’ve seen this harness jiggle loose and cause problems.
hope this helps you...
Oct 27, 2009 | Kenmore Elite 45986 Front Load Washer
Fh error code
Jun 08, 2009 | Kenmore Elite 45986 Front Load Washer
Computer on Kenmore HE3 Elite washer
Remove the outer shell - and the timer/CCU is replaced from the inside.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore f03 error message
check motor if noisy or hard to turn its motor, also check concetions to&from ccu board and mcu board . "less soap plz"
Oct 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,796 people viewed this question
fordexpert
Archaeology
Archaeology
