Question about Sanyo EM-C1800 Microwave Oven
What is an e32 fault and how do i fix it - Sanyo EM-C1800 Microwave Oven
KOR-63F7SL Timer Sticking
Generally you are better off having it replaced, unless you know someone that is handy at mechanical repairs, there might be a chance to fix it.
Apr 16, 2012 | Microwave Ovens
Tip
Get a Tech?
You know that's always my advice anyway. Some things can be fixed, and are straight forwards but I have been doing this all now for over 30 years and I still get stumped... A lot of faults aren't just straight forwards and are often "Chain" faults, meaning you MUST fix the source of the problem NOT the "Symptom" and repairs often must be made to "Other" seemingly unaffected areas, to stop other faults developing from the "Stress" the faulty components have placed on support componentry. Many times I cringe when I think of people working inside things that operate on the Mains.. especially Microwaves, more tech's are killed each year by these than any other single thing. Followed by TV sets.So yes you are right.. It may cost you but.. The woman complained as she watched me fix her device, she said I saw you, all you did was hit it with a hammer.. and you charged me $100, Well,NO, madame was my reply. I didn't charge you $100 to hit it with a hammer, No, I charged you $1 to hit it with the hammer, and $99 to know WHERE to hit it. 'Nuff said.
on Feb 12, 2010 | Microwave Ovens
1. Flexible joint at base of cleaner. 2. Fixed pipe connected to 1. above
Your question is under the Microwave Faults heading and clearly it is not a microwave fault.
You don't mention a make or model and only half a line of the fault is shown.
Please set up a fresh query.
Thank you.
Jan 11, 2011 | Microwave Ovens
The push button to open the door does not engage door, so door does not open
in most cases this is due to a snapped of push bar as they are made of plastic its a common fault. if the push bar is not snapped then its lost a plug that holds it in. as the microwave holds a constant 1000 watts of power i always recommend to people to have them fixed by lic techs the repair cost for this fault is around $ 100 if the part is still available
hop this helps please rank advice below
Dec 28, 2010 | Whirlpool GT4175S Microwave Oven
Little card bord looking thing inside microwave has burned can iget a new one
Yes you can fix it . it is easy to replace , it can be bought on the net or any good shop , buy a replacement that fits most m/waves and cut to size. or google make model etc. have had fault many times Replacement will fix problem most certainly,
pete
Nov 11, 2010 | Microwave Ovens
My microwave just stop running while trying to re heat . how im going to fix it. is their any reset button
in most cases the reason for microwaves shutting down without warning is the fuse. in some cases the fuse will fail at its own fault. to test the fault we would do a tollerence test on the unit. but the best way for you to test it is to replace the ceramic fuse with another of the same value. if the unit works then its a faulty fuse. if the unit blows the fuse then the unit has a fault in the power supply that needs to be repaired by a service tech.
best of luck
Aug 03, 2010 | Microwave Ovens
My microwave won't power up
if buy you mean there is no power check the fuse replace with same if it blows toss it in the bin. microwaves have many high power devices that makes them expensive to fix. in some cases fuses blow through there own fault but if replaced and they blow again its a in bread fault that needs to be fixed by a pro tech
godd luck hope this helps you
Jul 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The clock seems to loose approximately 4 minutes over a period of 12 hours.
You haven't specified which Whirlpool model you have, so I can only give a general answer which would apply to the same fault on any device with an electronic clock.
The only fix is to have the timer circuit replaced.
It's a solid state timer and non-adjustable, but can become inaccurate if the oscillator crystal goes out of tolerance. Considering the billions of timer circuits manufactured, there are remarkably few which suffer this fault, so you've just been unlucky.
Jan 14, 2010 | Whirlpool Microwave Ovens
Need help with model # mw8115ss 1450 watts microwave problem???
The fault may be on the system controler board. This may be a protection fault, or a fault with the logic control.
You can call the place where you bought the oven to find out where it can be serviced in your area. Most likely the tech will change the system controler board, or if there is factory authorized component level fix he will do that for you.
This is not something you will be able to service yourself.
Jerry G.
Sep 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Apr 19, 2008 | Microwave Ovens
Sanyo EM-C1800 Microwave Oven Logo
47 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
