Question about TMI Products Vizualogic Headrest Pair w/DVD Lincoln Navigator 05-Up Dove Gray Car Video Player
I purchased a 2007 escalade with the visualogic dual dvd headrest, we have had the vehicle for a month and the dvds have stopped working about 3 weeks ago, I have tried everything I can think of and we cannot get the power to turn on , it will not do anything, simply doesn't work.
Could it be a blown fuse in my brand new car the reason power outlets are non operational
the outlet may only be active when the key is the Acc or run position.
Suggest that you try DVD on another car it is possible the 12 volt DC operation in the new DVD is not working but the power cord does.
It is easy to pop the fuse when inserting the adapter. When you find and replace the fuse buy a spare.
Car manual will show fuse location. It is likely a 15 amp.
hope this helped?
Mar 10, 2016 | Televison & Video
Blower fan will not shut off even with truck turned off
Don't worry pal .most or intelligent systems won't shut off till it gets safe temperature.when the temperature gets in safe range it'll get automatically shutdown.so don't plug it out till cooler stops.
Nov 20, 2014 | Dual 2007-2009 Chevy Silverado 2500...
Installed dual DVD headrests, they both get power to them because the buttons light up...one screen flashes white then turns black, the other screen stays white. None of the buttons do anything, not e
Sorry I can't help you but maybe you can help me. I also ordered a set of these Anbotek DVD headrest players on ebay a few months back and trying to figure out how to install them in the minivan. Did you get any instructions? If so how did you get power to them so they work? Any help would be appreciated. thanks
Jan 19, 2014 | TMI Products Vizualogic Headrest Pair...
My dvd players will not power on
Look under the seat and see if they are connected and someone hasnt disconnected them to stop the kids from annoying them whilst driving
Feb 27, 2012 | 2004 Lincoln Navigator Luxury
Trying to remove a headrest from passenger seat in 2007 xc90
push & hold button on headrest while pulling up
Feb 19, 2009 | 1990 Volvo 740
Dual DVD Headrest System
you could try an fm modulator which allows you to tune your radio to the set frequency and then gives you sound through your speakers
May 23, 2008 | Myron & Davis Myron Davis 6.0 " TFT/LCD...
Writing to DVD takes excessive amount of time
The problem is that you might not have sufficient memory. Try burning @ 8x. Burning DVDs at 16x is a speed higher than the speed @ which file transfer takes place within the pc. So the lack of availability of memory slows down the proces. I once had the same problem.
I hope u find it helpful sir...
Nov 05, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
TMI Products Vizualogic Headrest Pair w/DVD Lincoln Navigator 05-Up Dove Gray Car Video Player Logo
123 people viewed this question
Top TMI Products Car Audio & Video Experts
greg benton
Tommie Jones
Level 1 Expert
Marvin
Marvin
Are you a TMI Products Car Audio and Video Expert? Answer questions, earn points and help others
