Question about General Electric Microwave Oven
RUNS BUT DOESN'T COOK
GE MODEL JVM1660CB004 SER #AA989970A...WORKED FINE THIS MORNING TRIED USING IT A FEW HOURS LATER AND HEARD A SMALL POP SOUNDED LIKE EVERYTHING WAS FINE BUT NOTHING COOKED. REPLACED THE MAGNETRON ABOUT 4 YEARS AGO UNDER WARRANTY AS THERE WAS A MAGNETRON PROBLEM.. IS TIS STILL THE CASE?
  • douganorr Jul 20, 2010
    THANK YOU FOR YOUR HELP
  • 4,472 Answers
Yes if it is working but not cooking then it is a magnetron problem.
Thank you,
Lee
Posted on Jul 20, 2010
    I AM A DIY'ER. IS THIS SOMETHING I CAN TACKLE MYSELF, AND HOW DO I GO ABOUT THIS REPAIR?
Own Whirlpool microwave model MH7100XY, everything works on it, however it does not heat anything, heard a small pop and after that it does not warm or cook anything?????
The pop sound is an indicator the magnetron is gone that heats the food. It is cheaper to replace the microwave oven than have it repaired.
Mar 19, 2011 | Whirlpool MH7140XF Microwave Oven
Periodically the VFD display will start to flicker while cooking, usually resulting in it resetting - stops cooking and all the VFD elements light up. It won't restart a cook cycle until I set the time and...
See this FixYa solution, even if your model number is different.
Dec 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-405k microwave stopped cooking
Well, it sounds like a bad relay. Easily fixed by a repair shop.
May 05, 2009 | Sharp R-405KS Stainless Steel Microwave...
The microwave was cooking, a few seconds later it ceased working
If it's not making a strong buzzing sound or anything out of the ordinary, it's probably the Magnatron. Most of the time that's what I find. It's the "antenna" that creates the microwaves. Some ovens carry a 5 year warranty on that part so I would check your manual. They are very easy to replace most of the time. They usually run about $100-$150.00
Feb 15, 2009 | Microwave Ovens
Microwave will not cook
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Oct 27, 2008 | GE JE2160 Microwave Oven
Microwave running although not turned on
Thought I had answered this, but this is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New microwave; loud fan when heating items
Since you say it's new, it should be under warranty. I would call GE (see your owner's manual) to get a local authorized service center. Then while you're on the phone with the service center, you can start it up and hold the phone close to it to demonstrate to the technician how loud it is. They should be able to tell you if it will be covered under warranty so you get it fixed free.
Mar 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Runs but makes a super load pop sound with flame
It sounds like you're saying a flame and pop came out of the area where the internal electronics are? If that's the case, then I would suspect a failed high-voltage transformer, bad magnetron or that another high-voltage component is arcing, like maybe damaged wiring, but that's rare unless... ... I hate to suggest it, but maybe a "critter" has made his way into the high-voltage section! That can cause some really "interesting" effects! If the flame and pop are coming out of the cooking cavity, then it could be food debris or grease underneath the waveguide cover or in the waveguide. I would say the likliest cause is a failed HV transformer. If it's still under warranty, I'd call Sears right away to verify that. If it's not under warranty, you may want to pull it from the wall yourself and take it in to Sears or another shop yourself. You'll probably save about $50 as opposed to letting them come out to the home to service it.
Oct 04, 2006 | Kenmore 62642 / 62644 / 62649 Microwave...
General Electric Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
