Question about Cameras
Hello i have dsc-T300 it says lens is closed what can i do to turn it on.
  • halimah35 Jul 18, 2010
    hello i have dsc-T300 it says lens is closed what can i do to turn it on.
    President:
  • 1,194 Answers
Make sure battery is fully charged, Try reseting your camera to factory default settings.
  • Turn off the camera.
  • Remove the battery pack.
  • Remove the button-sized lithium battery.
  • Allow the camera to remain without power for 30 seconds.
  • Reinsert the button-sized lithium battery.
  • Reinsert the battery pack.
  • Turn on the camera.
I hope this will solve your problem otherwise service may be required.
Thanks for using fixya,
Good luck and have a nice day.
Posted on Jul 18, 2010
  • 12,061 Answers
This may be a real Flat Battery, what you could try is a replacement battery, if this doesn't fix it, then it must have developed an internal fault, and should be returned to the service agent for a quote for a repair.
I have a sony DSC T300 that the back touch screen doesn't display any video. It lights up and I makes the noise when I touch where the scroll arrows are (when in play mode) or where menus should be (in...
Hi your unit has lens unit defectiveness. It won't reset itself initializing. The noise come from initializing IS unit defect. your local repair shop would charge around $45 to 115 depend on what they really want to charge. thanks and best regard!
May 25, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
DSC-T300 vibrates
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process
Sep 27, 2010 | Sony Cyber-shot DSC-T300 Digital Camera
My camera is broke
my dsc-t300.....there is a constant vibration in my camera and when i take pictures there blurry, i think it has to do something with the lens. how do i fix this?
Jul 20, 2010 | Sony Cyber-shot DSC-T300 Digital Camera
T300 vibrating every time I turn it on.
Turn off the image stabilizer in the menu, this may stop the problem and will turn off the gyro in the lens. The gyro is causing the problem.
Jul 01, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
HIII.I have DSC-T300 SONY CYBERSHOT CAMERA which is brought 1 year ago.It has started giving fuzzy images and by any adjustment I am unable to solve problem.Plz suggest soution...
Clean the lens with alcohol and Q-tip, If dirty lens is not the issue then the focus has stopped working and there is not a user serviceable solution. If sending for repair is not cost effective then you have nothing to lose by removing the battery and dousing the lens assembly with alcohol or spraying with Tuner Cleaner (from and electronics shop) Once it has had ample opportunity to dry out, try it again.If the problem was mechanical the cleaning will free up the lens assembly. If it's electronic then repair is likely to be close to what the camera cost or more.
Jun 20, 2009 | Sony Cyber-shot DSC-T300 Digital Camera
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
