Question about Lexmark P4350 All-In-One InkJet Printer
Printer will not accept any type or size of paper initially
  • Lexmark
    Lexmark Jul 20, 2010
    Check in the feeder for any foreign objects or obstructions along its way. I suggest not to load too much paper in the feeder. Use the media/paper specifications for the printer.
  • grandpamoses Jul 20, 2010
    appears to be something at start of feed not working.
    have to decide whether to repair or replace.thank you for your support.i do not have credit card access which is why i did not continue.My thanks to FixYa.
    grandpamoses.
  • Official Brand Answer
  • 3,344 Answers
Try to make sure there's nothing in the feeder that's blocking the way. Load a single sheet of regular paper. Then try to print. If problem persists, it might be a hardware problem in the printer itself. If that's the case, I suggest you contact Lexmark Technical Support at 1-800-539-6275 to further investigate the problem. That is free of charge. Thank you for choosing Lexmark.
Posted on Jul 20, 2010
Testimonial: "quite an interesting episode.to think that someone on the other side of the world can help me with my problem is amazing.thank you guru, have a nice day. grandpamoses.huon,aus."
My printer will not accept photo quality paper
The printer should accpet every paper only requires adjusting the feeder area fo every new brand paper that is inserted on device. Inspect the devices feeder compartment for appropiate size requested of the paper. Also, the printing paper has size adjustment details required to fit into the printer. Once observed, the feeder compartment would require manually adjusting to fit new paper size to achieve printerbility. Also, power on the computer to test print the new adjustments. The printer commnads too allows to sleect the appropiate shapes requested considerign the type of pape inserted in feeder comparments. Circumspectively, perform printer feeder compartment adjustments and test print a page to ascertain the most possible condition ot the new settings.
Feb 04, 2011 | HP PSC 1410 All-In-One InkJet Printer
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Im trying to make legal size copies
Check your owners manual to see what the acceptable paper sizes are. Legal paper is 8.5"x14". If legal paper is listed in the acceptable paper sizes there should be a tray to handfeed this size paper. Look for the term "single sheet manual bypass" in the owners manual. I beleive this tray or slot is on the left hand side of the printer.
Dec 06, 2010 | Brother MFC-7340 All-In-One Laser Printer
I REPLACED MY INK CARTRIDGES. I WAS PROMPTED TO
Ignore the error and continue printing. The print job might still be acceptable even if the paper size and paper type settings are not an exact match.
  1. Press Enter on the control panel to clear the error message.
  2. Try the print job again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
    Use the HP product software, also known as the printer driver, to change the print settings for your paper size and type depending on your version of Microsoft Word.
    1. In Microsoft Word, click File , and then click Print .
    2. Make sure that your HP product is in the Name drop-down list box, and then clickProperties .
    3. Click the Features tab, or the Paper/Quality tab.
    4. Select a paper size from the Size drop-down list.If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
      1. Select Custom from the drop-down list.
      2. In the Custom Paper Size dialog box, type a name for the new custom size.
      3. In the Width and Height boxes, type the dimensions.
      4. Select the unit of measurement, and then click Save .
      5. Click OK to close the Custom Paper Size dialog box, and then click OKagain to close the Properties dialog box. NOTE: You must exit the Properties dialog box to apply your changes.
      6. Open the Properties dialog box again, and then select the new custom size from the Size drop-down list.
    5. Select the paper type.
      1. In the Paper Type or Type is drop-down list, click More .
      2. Click the desired paper type, and then click OK .
    6. Select the paper source from the Paper Source drop-down list.
    7. Change any other settings, and then click OK to close the Properties dialog box.
    8. Try the print job again.
      Paper mismatch errors occur because the printer scans the width of the paper before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper Mismatch' or 'Paper too Narrow ' error.The error message might also display when you load the correct paper, just reinstall the printer driver if above procedure does not helps. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jul 10, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP DesignJet 430 wont accept media
This is the problem with the sensor. It tries to read the size of the paper, the sensor is on the side of the carriage assy(cartridges are installed on this assy). You can try cleaning this sensor or get it replaced or some times the service center will replace the carriage unit as a whole.
Dec 01, 2009 | HP Office Equipment & Supplies
Will not accept the paper to print
try making sure that the paper being used is dry not moist or wet and that the edges are straight. that should fix it
Oct 10, 2009 | HP DeskJet 940c InkJet Printer
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
Phaser 6250-Tray 2 continuously ask for A5 Paper
Adjust the side guides in the paper cassette tight against the paper stack.
Jan 25, 2009 | Xerox Phaser 6250DP Laser Printer
Unusual paper size
Load the custom size paper in Paper Tray 5 (Bypass Tray). The Tray 5 screen will be displayed on the Touch Screen. Select [Non Standard Size] from the column on the left. Select the [Up] or [Down] arrow button to modify the X dimension of the custom paper size. The value range is from 147.32 to 457.2 mm (5.8 to 18.0 inches). Select the [Right] or [Left] arrow button to modify the Y dimension of the custom paper size. The value range is from 147.32 to 297.2 mm (5.8 to 11.7 inches). Select the appropriate paper type from the Paper Type column on the left. Select [Save]. Select [Tray5] from the paper supply section under the [Basic Copying] tab. Make any other required selections for the job from the Basic Copying tab on the Touch Screen. Place the original(s) in the Document Feeder or a single original on the Document Glass. Press the [Start] button on the Control Panel to copy hope this helps!!!
Jul 29, 2007 | Xerox DocuColor 12 Printer
Paper sizing error
Solution #2 WORKS! Just when you use the #clear option.. select "ALL" it will reset everything but all you have to do is simply re set the paper size to letter as it seems to default to A4 size once it re-initializes. What a nightmare this was..
Jun 29, 2007 | Canon imageCLASS MF5750 All-In-One Laser...
Lexmark P4350 All-In-One InkJet Printer Logo
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
