Question about Acer Computers & Internet
Acer apire 4715Z keyboard problem
Need help please, when i press the Z button i get a Q and V i get T and B i get U and space bar i get J what is the problem can somebody help me i dont know what to do i cant use my laptop.,
  • ecinue_13 Jul 18, 2010
    its in US sir., or can it be solve if i format my laptop??
  • ecinue_13 Oct 11, 2010
    thanks sir, ive already try reinstalling windows, reformat it, but nothing happens, i think it is a keyboard replacement? would it be possible sir?? i think soda but just a little, and i try also remove all the keys then clean it all the dirt i removed sir but still nothing, haay do you know sir how much is keyboard replacement in my acer 4715z laptop?? thanks again 4 the effort!!
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Regional Settings
Make sure that your "input method" is set to "US Keyboard".
Or, it could be a malfunctioning keyboard.
A laptop keyboard is not a "user-replaceable" part.
Try connecting a USB keyboard, and see if it works correctly.
Posted on Jul 18, 2010
  • 3 more comments
    sir i connect a USB keyboard and it is working fine, is there another solution sir?? thanks sir!!!
  • ikkenom Sep 03, 2010
    I doubt that reinstalling Windows will solve the problem.
    Borrow/buy an external USB keyboard, connect it, and try if, to see if Windows correctly recognizes each key-press, i.e., press Q, get Q. If it does, then Windows itself is OK, and it's your keyboard that is malfunctioning.
    Did somebody spill something (soft drink? coffee with cream & sugar?) onto the keyboard, and did not own-up to doing it?
    thanks sir but i already try reinstall,reformat,change windows, but again nothing happens, and i also try removing all the keys one by one and clean it (fail again)
    i think a little of soda pour in keyboard but i clean it also, i think its keyboard replacement sir? how much it'll cost in my acer aspire 4715z laptop?
    one more thing sir um the original os of my laptop is vista starter and i change it to windows 7 coz someone say that it is compatible i search the net for drivers and i found but its in vista home premium it says its compatible with widndows 7 and i install etc and drivers all ok, do you think it nothing connection with my keyboard problem? thanks sir! godbles!!
  • ikkenom Oct 11, 2010
    >> I think its keyboard replacement?
    If the external USB keyboard works correctly, then I agree that it is time to replace the keyboard.
    Probably around $50 for the new keyboard (maybe less if you can buy on on eBay)
    and another $50 for "labour" by a technician to safely/correct change the keyboard.
Wireless switch location for acer aspire 4715z
It is the last button on the left side of the keyboard near shift key with Signal up logo (I think with yellow light, when enable) that enables/disables the wireless adaptor.
Hope it helps,
CreativeTECH
May 24, 2013 | Acer InviLink 802.11b (91.49C10.002)...
How do you use the euro sign on keyboard what do u press
Press the ALT-GR button on the right side of your keyboards space bar. Use it together with the e
Jul 07, 2011 | Acer Aspire Z5700 PC Desktop
Some of the keys are not functioning properly they are typing numbers instead of letters and the space bar is also typing a number? Please help!!
There is probably a function button on your keyboard. Pressing that button should fix the problem. It might be labeled Fn. (Look near the bottom left of the keyboard.) Best Wishes!
Mar 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
Icant.press.the..space..bar
assume this is an acer laptop keyboard?
Sticky key: gently remove the space bar noting how the retaining clips fit. Clean under the bar and around the rubber buffer with isopropyl alcohol or similar, test before refitting the bar, if this does not resolve the problem, you may be looking at a partly damaged keyboard and will need to replace
Jan 27, 2011 | Acer NSK8458AN Keyboard
Space bar on ACER TravelMate 2304LCi laptop doesn't work
Unfortunately, Keyboards on laptop is a set. You need to replace the whole keyboard. If you have skills, you can try dismantle it and clean the area of the space bar within the membrane.
Hope this helps.
Dec 20, 2009 | Acer TravelMate 2304LCi Notebook
Onmydelllaptop,thespacebarwillnotspacenormove
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Left side space bar does not work
The space bar on any PC is a single button you may need to make sure your keyboard is clear of any debris If that doesn't fix issue you will probably need to replace keyboard which is very easy to do. techsupport@grindstaffscomputerservices.com
Mar 18, 2009 | Acer Aspire 5735 Notebook
Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
Dec 28, 2008 | Acer Aspire 1360 Notebook
Computers & Internet Logo
197 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
