Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
What causes blue dots all over the screen of a 52" tv
What causes blue dots all over the screen of a 52'' Sony LCD high definition tv
5 Suggested Answers
SOURCE: Blue dots on LCD screen, Sony tv.
You probably need a new optic block. The part alone is approx. $900.00. Sony has had this issue with most of their rear projection LCD televisions. Sony was offering to either repair the tv or give you a substantial credit [$1100.00 or so] towards the purchase of a new Sony LCD flat screen but I believe this program ended in December of 2008. You may still be able to call Sony customer service and plead your case. Good luck!!
Posted on May 22, 2009
  • 197 Answers
SOURCE: Blue dots on Sony rear projection LCD tv KDF 42WE655
you have a bad optical block
Posted on Jul 02, 2009
  • 65 Answers
SOURCE: Vizio 52 Red dots
It sounds like you have a defective LCD panel. This is more common with the plasma TVs. Are you sure it's an LCD?
Posted on Aug 01, 2009
SOURCE: Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Posted on Sep 04, 2010
Sony kdf-e60a20 tv has blue dots and yellow smudge 0n screen how do i repair problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 14, 2014 | Sony Televison & Video
Sony wega lcd tv blue dots
thats caused by the optical block which is very expensive to replace. Sony has had alot of issues with the blue dots on the screen its not worth repairing due to the high cost of the optical block
Feb 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
52" Sony Bravia TV has a thin Blue line down left
A line on an LCD screen can be cause by the screen itself going bad or the T-con board. The T-con board the attached to the screen on the backside and covered by a heatshield. If you get teh part number from it you can find it online from one of the many retails that might have it. Like www.interliquidparts.com
Jun 06, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
There is a blue image/dots in the middle of the screen. Can this be repaired. I think this was created by hooking up a Sony Playstation to the TV.
Something like that shouldn't be caused by just hooking up a playstation. However, leaving a certain picture on the screen could cause burn-in (it's rare on newer TVs though, but it definitely happened on mine).
Mar 08, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Oct 05, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Blue dots on the screen of a kdf50 grand wega
Sounds like some of the pixels on the LCD screen are not turning on which is causing the blue dots to show. (I would guess that the dots are always in the same spot.) On a normal TV these would be unlikely to be a bother, but since the Wega is a projection TV these are no doubt being enlarged on the final viewing image and so are hard to ignore.
If that is the problem there is not a lot you can do about it. If the TV is still under guarantee I would return it to the shop ASAP. If not then I suspect the cost of repair will be quite high, if not impossible other than back at the factory.
Sep 22, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a SONY LCD TV model KDF 50WE655 w/ Blue Dots on screen :(
The blue dots are cause by a defective optical light engine. This parts is quite expensive.
Read the info from this link for more info.
Jul 02, 2009 | Televison & Video
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
