Question about Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
How do you get the pump out of the housing on a jucuzzi magnum force pump
  • 760 Answers
If yours is the model with the big round ring around motor, it is a large retaining nut. Remove this nut and the motor should come from the pump housing. Don't be too rough, plastic breaks.
Posted on Jul 18, 2010
My jacuzzi magnum force pump is hot is this normal?
the pump is pumping and circulating hot water into jacuzzi, it will get hot. I think it is ok
Jul 06, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
I need a motor end cover, where can I get one? Thank you!
Jacuzzi (Carvin) Magnum, Force & Plus pump parts are hard to find.
Here is a link to our site which has a parts explosion/diagram for those pumps.
Jacuzzi Magnum, Magnum Plus, and Magnum Force Pumps
Jun 08, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
I have the wires undone the locking ring is off nothing I can see that is holding the motor into the pump housing. Can not get the motor to come out of the Magnum Housing. What am I doing wrong or forgot....
There is nothing else you need to loosen; your pump is simply stuck. It is common for Jacuzzi pumps to be difficult to take apart. You need to keep working the motor side-to-side and up & down till it finally frees from the housing.
John
Jan 29, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pump housing is cracked and lealing. Is there any
the pump housing is available through your local pool dealer. It is broken down into 3 sections the pump, housing and Pod.
The Pool Tech
Jul 01, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Motor removal on a Jacuzzi magnum force pump.
The impeller is threaded onto the end of the motor shaft and the housing (pump body) is attached to the motor with the same bolts that hold the rear cover on the motor they run all the way through on most pumps.
May 27, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Which valve do I use on the Jacuzzi Magnum 1500 to drain lines
There two plugs on your pump, one one the side of the pot at the bottom and one dead center of the pump housing on the front. this will only drain your pump if you live in cold country and are winterizing you will need to drain all your equiptment filter, heater and any thing else. then you need to drain your pipes and seal them at poolside to keep the water out.
Sep 26, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
There is a small crack in the pump housing and it has created a pinhole size leak. Is there a way to fix this, or do I need to replace the housing?
Ideally you will need to replace the wet end (not the whole pump) but there are products like LS-X made by fernox that will seal such a leak.
Jun 29, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a Jacuzzi Magnum force pump
Good luck...Jacuzzi went out of business. The best source I have had for their parts is CCO:
http://www.jbparts.com/jbc0001.html
Jun 01, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Getting to impellre
the impeller is what is holding it in on the end of motor is the impellel the impeller is in a houseing right off motor that is held togethere by screws you should disconect power then power for motor then remove water in/outtake there may be some kind of strap holding it down
Feb 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V Logo
240 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
