Question about KitchenAid Artisan
Kitchenaid artisan coffee machine - steam wand does not emit enough steam to froth milk
  • 906 Answers
Good day,
hope this link below will solve your problem..
kitchen
Posted on Aug 04, 2010
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
How do i use the steam wand to froth milk
The steam wand to froth milk, you need a certain amount of milk in the cup first, then if you tilt the cup a little towards you, push the steam button and "it should froth your milk right up", but if that doesn't work then I don't know.
Mar 24, 2014 | Bella Espresso Maker - Black
Froth
If you are getting steam out of the wand I suggest you practice and work ha and to learn how to froth up the milk. The machine does not froth up, it is the operator who does. You basically need to keep the wand just below the milk level and keep moving very slowly up and down always trying to stay below the milk level. If the container is wide you may need to swirl as you moving.
Mar 14, 2013 | Saeco Coffee Makers & Espresso Machines
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
The steam wand emits a very thin and weak stream of steam making it impossible to froth milk. Should I descale the machine? If so, can I use spirit vinegar?
Decalcification of coffee machines boilers is better to be done with special powder for decalcification in aluminum. For making the solution from the powder you must go by instructions of manufacturer of powder. Anyway you should clean the pipe too, you get glass of water and put pipe in, steam up until it boils, than you live it for 3-4 hours. Softened milk sedimentation's will come out easily if they are present.
Feb 24, 2011 | Gaggia Baby Espresso Machine
My steamer wand has an awful odor everytime I try to steam something! I have cleaned it (even soaked in baking soda!) and the problem won't stop. Anyone else have this problem?
This is a common problem for the commercial espresso machines, Due to lack of cleaning of the steam wand after they finish frothing milk.
The milk flows back to the boiler and the water gets contaminated with milk.
Does the steam smells like rotten milk? If the answer is yes, you have contaminated water and or lines.
If not may be there is a lot of IRON in the water.
Run a descale cycle.
After you are done frothing milk, wipe the steam wand with a wet towel and open the steam valve for 2 seconds, close it and that's it.
Jan 15, 2011 | Saeco Starbucks Sirena Espresso Machine
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
My machine will not froth milk
Nov 01, 2009 | Saeco Starbucks Sirena Espresso Machine
Weak steam flow from milk frothing wand.
This is usually a sign it needs a de-scale. you can get a de-scale solution from most coffee machine retailers. Vinegar can be to harsh and ruin your seals. After frothing your milk make sure you let some steam through without milk to clear milk that can be sucked up wand. You can get cleaning instructions of Saeco web site. Good luck
Sep 10, 2009 | Saeco VIA Venezia
Steam problem
If the milk scalds, you're getting it hot enough. It sounds like you're not incorporating enough air into the milk when frothing.
Make sure that the holes in the tip of the steam wand are clear. Soak in water for 5-10 min. and wipe with a cloth (no abrasives) and clear the holes with a paper clip end. Blow the wand out nice and hard.
How is your steam pressure? It should be about 1.2 bar.
It could also be your technique. The wand should never be more than 3 cm into the milk. For cappuccino froth, keep the tip right at the surface of the milk, lowering the pitcher as the level rises. You should hear a "shushing" sound, no squealing.
Aug 28, 2007 | Rancilio Silvia Espresso Machine
KitchenAid Artisan Logo
822 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
