Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi projection TV VS-4561 Vertical Hold issue
My TV is now rolling when I turn it on for about 10 min and then it stops. Is there a easy/cheap solution.
Joe
  • 927 Answers
Good Day, Maybeitstime:
Joe the cheapest way is to repair it yourself and this is what you need to do:
VERTICAL JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTIC's (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND). As you can see this might be over you head but for a 1994 model you did get 14 years of watching TV enjoyment. 'Might think about replacement. Good Luck, big IRISH.
Posted on Jul 31, 2008
I have a Mitsubishi VS 50605 projection tv that needs to have the vertical hold reset. How do I reset it.
Put it back to the mid point of it's adjustment range.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced..
Sep 10, 2014 | Mitsubishi WD Televison & Video
Rolling lines until tv warms up
Vertical output IC bad capacitors in vertical circuit 100uf 35v sometimes vertical IC needs to be resolder and that fixes problem look for poor solder joint s.
Sep 27, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
I cannot find vertical hold
The sync is automatic. There are no knobs to turn. If the picture is rolling, look first to the source connection and make sure your tv has a solid vertical sync connection. If you are using the RF input then the issue could be within your small signal board also known as the SSB. Good luck.
Mar 23, 2009 | Televison & Video
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Hi, Vs-4561 MItsubishi rolling picture
Good Day, pleasehelptv;
Those caps may be the problem but try this:
VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING,VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
HOPE THIS WAS HELPFUL.
May 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
590 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
