Question about Maytag Refrigerators
I have Maytag side by side fridge model RSW22A. The center post is very HOT. Its too hot to touch. Is this normal? How do I fix it? Thx.
  • 87 Answers
SOURCE: maytag refrigerator MSD2758GEW divider panel hot to touch
What you could check is that the fan at the back of the unit, where the compressor is located, is working, as this could also cause a heat build up. The partition between the two sides does generally tend to get hot due to the door circuit, to prevent ice buildup around the door. But people tend to notice when something is different. You are also right to check for dust underneath the cabinet as the condenser tends to be layered. If you have already cleaned it all out then you have probably done as much as you can. If you are still concerned contact a fridge guy. Hope this is of some help.
Posted on Sep 12, 2007
SOURCE: Center divider of refrigerator is
Turns out a circuit board had failed and the fan (back of frig) was not working. Because of this, coils were overheating which triggered the icemaker to stop functioning. Until the part was replaced, we put a portable fan in the back and within a day, things were cooling down and the icemaker was functioning again.
The part with installation was $200. Took less than a week for the part to arrive.
Posted on Jun 19, 2008
mikedurland
  • 481 Answers
SOURCE: Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Posted on Jul 10, 2008
SOURCE: Maytag side by side fridge.
My Maytag side by side #MSD2957AE center front between the doors got very very hot. Too hot to touch. Also the top outside of unit and cabinet above unit unusually hot. I was worried and wondered if it could start a fire. I pulled out from wall and found lots of dust naturally. But the fan was not spinning. I moved it with my finger and it took off spinning. Unplugged, vacumed dust as best I could. Replugged and the fan started spinning on it's own. I plan to watch it. Also clean around the fan motor better, even pull it and lube it with some silicone spray. After running for a while center post is warm but not hot. thank you. JOE.
Posted on Aug 22, 2008
Maytag317
  • 1136 Answers
SOURCE: the center of the fridge between the freezer and fridge is so hot you cant touch it whats wrong should I call a repair person ? thank you for any help
HI, this is a sign the fridge isn't cooling proper. Check and see if there is frost building up on the rear panel of the freezer. Check and see if the evaporator or the condensor fan motors are running. Check and see if the compressor is running.
Pleasae let me know if I can assist you fyrther.
Vic
Posted on May 21, 2009
The center bar between the freezer and refrigerator is very hot to the touch. Also about halfway down on the freezer size is also very hot. The ice cubes also seem to be smaller
Heat is normal but the freezer may not be clod enough. Check temp in freezer(0 deg F or -18 C. Also check rear wall of freezer for frost . If so you have a defrost problem which will raise the temp in the freezer. Also check that the condenser fan in the rear bottom of the fridge is running and the condenser is clear,
Nov 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
The doors are scorching hot to touch on my Maytag 2454. It's always been warm to touch, but all of a sudden it is too hot to even touch. It is in the center part of both doors, along the door seal area and...
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Apr 22, 2010 | Maytag MSD2454G Side by Side Refrigerator
Whirlpool Gold side by side cabinet extremely hot to the touch.
the refrigerator has mullions simaler to the veins underneath your skin to aid in cooling .the first thing to check is the fan by the compressor is it running while the compressor is if so the next thing to inspect is the condensor coils usaly underneath the fridge or directly on the back of the fridge alot of times these get clogged with lint and or animal hairsimply unplug the fridge and gently brush off the lint and vacume.your feed back on the resolve for this issue would be gratly app.
Aug 13, 2009 | Refrigerators
CENTER METAL SURFACE THAT DOOR SEALS TOUCH WILL BURN YOUR SKIN
go to partstore buy the part # DA97-01949A and fix it you can put the fan in back refrigerator keep it cool when the part come and fix it
May 11, 2009 | Samsung RS2630SH Side by Side Refrigerator
Compressor very hot + water leaking
This is not normal. The coolant charge is low which means it leaked out some where. Return it.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Outside freezer hot and seals
Fridge has either mullion heaters around door or most likely steel pipes just inside the skin of the perimeter of the door, this is to stop ice or condensation forming around the door seals, mainly the freezer, they are part of the condenser circuit ( hot part of the refrigeration system).
It is normal for these to get hot, but in your case may be hotter than usual because of the constant running, the running may be caused by hot ambient temperatures, system being slightly short of refrigerant, faulty thermostat or in-efficient compressor.
I suggest if temp is ok inside fridge dont worry too much, if you notice fridge starts loosing its capacity to refrigerate, have a refrigeration tech look at it.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Space between doors on cabnet is very hot to touch ref seems to work ok
hi. thanks for the question .the heat between the doors is normal . its hot to keep condensation from running down the doors .but pull fridge away from wall. remove back panel and clean all the coils. very important. thanks the appliance doc
Sep 30, 2008 | Maytag 23 cu. ft. Side-by-Side...
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge is getting hot in between the doors
This is called a mullion heater and is perfectly normal as this heater prevents the area between the doors from freezing. No danger at all.
Mar 08, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My Maytag side by side is 7 years old. Bar between fridge and freezer just began getting very, very hot also? What can we do to repair? Does the condenser fan motor need to be replaced?
Oct 23, 2007 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
80 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
