Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Kenmore elite touch screen makes ice slow sometimes and sometimes it dumps fast.
catriver
  • 878 Answers
SOURCE: Ice Maker too slow
bayfishr, I'll try to give you an idea on how this thing works and let you do some checks. The cycle is controlled by temp. The harvesting process begins when the IM thermostat closes signaling the harvest temp has been reached. The closed thermostat supplies power to the IM motor and heater. Therefore the colder you keep it, the faster the production unless something has failed. I see a lot of heaters fail. You can test this. When the IM starts it cycle, test the voltage from L to H on the module,they will be marked. Should read 120V. The heater on the bottom of the mold should be getting hot. Disconnect the harnes and ohm it. Should ohm out at approx 72 ohms, same test points. If this checks good, check the center wheel on the module itself. Two clips keep the wheel in place. If one is cracked off, the IM will not fucntion properly. Other than colder temps, there is no way to adjust the speed of the cycle. Keep the flap in front of the ice-maker down so that the cold air is drawn across that IM. Catriver.
Posted on Aug 06, 2007
  • 62 Answers
SOURCE: Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Posted on Sep 06, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
Kenmore elite refrigerator 795.72063 ice make won't dump ice and water in the door is hot.what is wrong?
Pull the power cord for 30 minutes and see it it resets. Can we guess that the cold sections are still holding a cold temp?
Oct 30, 2015 | Kenmore Refrigerators
My icemaker just stopped making ice today....please help
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Free standing ice maker not functioning
Have you got a slow flash or fast flash?
A slow flash is a problem with the sensor.
A fast flash is dirty condenser failed condenser fan.
See page 16
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 15, 2010 | Kenmore 51lb. Clear Ice Maker
Kenmore Elite side by side wont distribute ice
you may try dumping the ice and rinseing the bucket make sure door switch is closed.
Oct 16, 2009 | Refrigerators
Ice maker stoped working
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Kenmore 57029 Side by Side Refrigerator
I have a kenmore elite fridg that is not making ice,but i have water at the door. modle # 50509990. THANKS.
Pour about 2/3 cup of water into icemaker ( if there is no cubes in there now ) . If the icemaker dumps the cubes when frozen , replace the water valve . If it doesn't dump , replace the icemaker . Also make sure the coils at the bottom of refrig in front , are clean of dust , lint , pet hair , etc . Also check the plastic hose inside the freezer , to the icemaker , to make sure it is not frozen . If it is , replace the water valve , due to slow drip leak .
Sep 05, 2009 | Kenmore Refrigerators
Ice does not dispense through door of kenmore elite side by side
take ice bucket out, dump ice, clean with hot water and let dry ,,,, put ice back in and try it ,,, bucket is most likely frozen up thru ports
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker slow to make ice
Tener, sounds like you have a module going bad. Pull off the white cover of the ice maker and take a look at the center white gear. There should be two clips securing the gear on. A lot of times these clips break and cause the gear not to rotate properly. Part number for the module is 628399. Take a look at this first. Catriver..post back
Nov 01, 2006 | Kenmore 53202 / 53204 / 53209 Side by Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
104 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
