Question about Timex Sports Ironman Triathlon 50-Lap 59231 Wristwatch
Replaced battery - won't switch modes!
I have an Ironman Triathlon 30 lap sleek watch. I replaced the battery and now the watch won't switch modes? Is there a reset? How do I get it to work> I can't even set the time - nothing works!
  • Gegyourt May 24, 2008
    How do you short out a watch?
  • 109 Answers
It could be that you need to short out the watch , or it could be that you moved the movement up a little so that the buttons do not hit the metal prong that hits the movement. To short out the watch, take a pair of tweezers and put one tong on the positive of the battery, and put the other tong on a place on the movement marked "AC", or "+". Hold there for a few seconds,that will do the trick. If the movement has come up on the casing, Take a thin screwdriver and push the prong towards the movement and away from the button on all buttons around the casing. You should feelm the movement drop a little, then proceed to put the back on. If you still have problems, PLEASE let me know, I will be glad to assist you further. Good Luck!!
Posted on Sep 08, 2008
Short out the watch again, it will work.
Posted on May 10, 2008
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Indigo light doesn't work
It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
Oct 02, 2012 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
My timex ironman 30 lap flix will not move to the chrono mode
From the time mode, just press mode button once and the word "chrono" will appear.
Jul 22, 2011 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
I just need online instructions to use the lap timer on my Women's Timex Ironman Triathlon watch. I'm not sure of the model, but I think it's a 50-lap, and it's small. The 4 buttons on the side...
Here is the link that can help you set up your watch. Also here is the All list of timex watch downloadable instruction.
I hope this can help you resolve your issue.
Thank you for choosing Fixya
Mar 06, 2011 | Ironman Timex T5B721 Sports 50 Lap...
How do you replace the battery in a ironman triathlon sleek digital watch
Thank you for contacting FIxYa.
Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • Remove the back case cover by gently prying it up with your screwdriver. Be careful to avoid disrupting any electrical contacts with the tip of your screwdriver.
  • Remove the interior sticker that covers the battery by lifting it up with the tip of your screwdriver. It should come off relatively easily. At this point the small circular battery should be visible in the compartment.
  • Lift up the small metal clip (battery strap) that covers the battery using the tip of your screwdriver.
  • Remove the battery from its housing and replace it with your new battery (available at any electronics store or online). Reassemble the watch in the same way you to took it apart.
  • Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    Timex T5E451 instructions PDF
    Hi.
    This model should be an Ironman 75-Lap Sleek (OVA).
    Here the manual:ENGLISH.PDF
    Here manuals for different Ironman models.
    Regards.
    May 15, 2010 | Timex Ironman Triathlon 75-Lap Sleek OVA -...
    Timex Sleek stopped beeping when I replaced the battery
    This is a common problem when non watch educated people are changing battries themselves.
    The answer is simple: While changing battery and handling the watch you did lost the coil spring. It is so small, you will never notice that the something was dropped.
    Coilspring is the connector to the sound membrane of the watch, transfering microprocessor signals to audible membrane.
    If it's lost, there is no connection between watch movement and audio membrane.
    I suggest that you did change batteries yourself previously and had the same outcome (no sound). Next time you gonna change the battery - make sure you do not turn the watch upside down and if you do - check the movement with eyeglass and make sure all the loose fitted bits are in place.
    To get your both watches fixed visit your nearest watch repair shop and ask for coilspring to be fitted.
    Rate me, please.
    Mar 26, 2009 | Timex Ironman 30-lap, Blue And Silver From...
    Eliminate half moon from dial of a Timex Ironman Triathlon watch
    You need to hold down the Indiglo button for 4 seconds. The half moon means that night mode is activated, and it will tuirn itself off in 8 hours (which I'm sure you know by know, seeing how it's been 5 years).
    http://www.sportswatchinformant.com/timex-ironman-watch-night-mode-feature/
    Nov 13, 2008 | Timex Ironman Triathlon Sleek 50 Lap 5G301...
    Timex Sports Ironman Triathlon 50-Lap 59231 Wristwatch Logo
    1,376 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
