Question about Troy Bilt 24b - 060f766 5hp Chipper Shredder Push Vac
Chipper/ Shredder runs for while on the amount you primed the eng
Primed the carburator by pumping the plunger 5 times it runs then stops. Prime again it does the same thing them keep finger on primer (pushing pmodel47lunger in) it runs for a while till i get tired of holding it.
model 47035
  • 760 Answers
Check to be sure there isn't a small hole or crack in the priming bulb. If there is it allows air to enter fuel line, loosing the prime. Most have a collar that unscrews to remove it.
Posted on Jul 18, 2010
Testimonial: "going to check it tomorrow hope that idsthe problemm dounds good "
  • Tom W Jul 18, 2010
    If you're holding it in, it could be the primer bulb. If you have to keep pumping it, you need a carb kit. There is a gasket that is a diaphragm and two check valves (little flappers) gas sitting in carbs destroys these parts.
I have intelliflo VS+SVRS pool pump, after stopping for 4 days i want to start again & after start it goes to priming & then alarm & it says clear the drain & restart
There is either something blocking the suction side of this pump (blocked valve, strainer, strainer basket, leaves on main drain.) or the pump is not getting primed in the aloted amount of time. You can increase the priming time on the pump, or manually prime it, or just turn off the svrs feature temporarily until you get a good prime again. If you need the manual to figure out how to do these things, here is the link.
http://www.pentairpool.com/pdfs/IntelliProVS+SVRSOM.pdf
Jan 19, 2011 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Lawn Boy Silver Edition, When Primed, it starts, Then Stops? help
High speed jet is plugged. You'll have to disassemble the carb
Sep 09, 2009 | Garden
Silverado not starting unless prime
There is a check valve in the fuel pump that sounds like it may have gone bad. Check the fuel pressure at the shredder valve, there should be 60 to 65psi during the prime and will drop 5 psi when the engine is running. Once the fuel line is primed, check to see how fast you lose your prime. Since you replaced your injection system, we can eliminate the fuel pressure regulator leaking which was common on the injection system your truck run's on. If the fuel pressure drops fast then it's going to be a bad check valve at the fuel pump and it may be time to replace the fuel pump it self. Good luck and hope this helps. Note: do not try to start the engine with putting gas through the throttle body, it's been know for small fires to start and burn the spider injectors.
Sep 04, 2009 | 1999 Chevrolet Silverado 1500
Airless sprayer will not prime Model AL230502LX
Check for a plunger on the bottom of the machine. Pump it several times and try to prime with water. Also, if there is difficulty priming after trying the plunger, switch on in prime, and cycle to paint, back to prime,paint,prime. After several tries, leave it in prime with the pickup tube in water, and pump the plunger again. If this doesn't help, disconnect the hose fron the pump and try again. If you're getting water now, the issue is down the hose, or at the roller/gun.
Hope this helps! --W/D--
Jul 12, 2009 | Campbell Hausfeld Airless Spray Guns &...
Noy working
Well, ok, I found that I just needed more water to prime it.  Apparently, a self-prime pump needs to be primed pretty well to use the first time.
May 23, 2009 | Dynamo Garden
Toro recycler will start until primed gas is consumed.
I had similar problem and cleaned the spark plug and that seemed to have worked, but I think that may be a temporary fix because the engine still seems to be running unevenly. I feel that it must be a larger problem with the carb. If anyone can help this novice to adjust the carb or clean both carb and filter, or offer other solutions I would appreciate your assistance.
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Troy Bilt 24b - 060f766 5hp Chipper Shredder Push Vac Logo
285 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
Ronny Bennett Sr.
Ronny Bennett Sr.
Wade Mobley
Wade Mobley
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
