Question about Intel Desktop Board RC440BX (KRC440BXPAK10) Motherboard
Intel motherboard Computer turns on but doesn't display there are no beeps when starring the computer
    Problem Solver:
  • 11 Answers
May be RAM problem if RAM problem occure then also display problem(some mother board does't contain speaker so According to beep code don't decide that motherboard ok or fault.
Posted on May 14, 2008
    Problem Solver:
  • 18 Answers
You may either need to replace your cpu or replace your motherboard. I couldnt really tell you which one without looking at it but It will most likerly be one of them. Thanks
Onlinepc-fix
Posted on Apr 24, 2008
I am using a intel Dh61ww board with intel i3 2100 processor. When i switch on the pc the cpu fan rotates and halts.no display. pls help me.
The steps I would take would be : 1 make sure you have a power supply with the proper power connections and at least 500 Watts 2 remove and reset the power connections, try to boot 3 disconnect all hard drives and cd/dvd's, try to boot 4 remove all ram/memory sticks, try to boot and listen for the beep or beeps if it doesn't beep and still shuts off, you have a bad motherboard and/or cpu if it does beep, you need to try different ram
Aug 23, 2011 | Intel Motherboard
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
As soon as power is turned on, I get 6 short beeps that repeat
6 short beeps in a row usually mean that the chip on your motherboard that controls your keyboard (A20 gate) isn't working.
First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
In case you do not want to replace that chip by yourself, and after trying other keyboards it is still beeping, then find your local IT guy.
If your system is still under warranty, you should just call provider(seller) of your computer first, as tampering with your computer may void your warranty.
Jul 06, 2011 | SuperMicro COMPUTER Supermicro...
I HAVE INTEL DG31GL MOTBOARD I HAVE ONE PROBLEAM IN MOTBOARD IS NO DIPLAY ONE SINGNAL LIGHT IS GLOW
Hell Krishna,
The display problem is common in all the Intel DG31GL motherboard. Please switch off the computer first. Then remove the Li-ion cell/ battery of the mother board. Replace it with new Li-ion cell/ battery.Also remove the ram of the motherboard. Insert the cell/battery in the motherboard and switch on the computer without installing the ram. After 2 to 3 beeps switch off the computer and install the ram and then switch on the computer. The display will come again.
Jun 01, 2011 | Intel Motherboard
MSI H55M-P31 board & having 2 2GB DDR3 modules and I7 Processors, installed memory on dual channel and sytem beeps 3 time and no display
Depending upon which BIOS make is installed in your computer, 3 beep means RAM fault.
Check the specification of your motherboard for the recommended RAM.
Reseat the RAM nodules in the motherboard.
Remove the RAM and get them tested at your friendly computer repair shop.
Sep 24, 2010 | MSI H55MP31 LGA 1156 Intel H55 Micro ATX...
No image
Does it beep if you try to turn the computer on without the graphics card inserted? If it does chances are only the AGP port died and you might still be able to boot the machine with an old PCI graphics card.
Jul 27, 2009 | Intel Motherboard
I have Intel DG31PR series motherboard with 2GB
The number of the beeps is a specific post
error code and should help diagnose. e.g.:
my computer has 3 beeps to indicate RAM
failure. Note the beeps and find in your manual
or from Intel support.
Here's some help to get started:
Beep Codes
Intel Support
Jul 12, 2009 | Intel DG31PR Motherboard
Motherboard power on but no display.
Greetings!
Check first if all the cable, wire are connected properly.
See also at the back of your power supply if the switch is on, cause some power supply have switch aside from your system unit.
Usually once you open your computer you can hear a beep sound if their is no beep sound means something wrong with your computer.
As you turn on the computer see the fan of your power supply at the back of your unit if it revolves if not something wrong with your power supply, if the fun of your power supply re volves it's your motherboard have something wrong.
Thanks
Nov 11, 2008 | Intel D845GVSR Motherboard
Intel motherboard C9810E
do not see a problem here, what do you want to hear and see when you turn your computer OFF?
Apr 21, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Desktop Board RC440BX (KRC440BXPAK10) Motherboard Logo
82 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
