Question about Craftsman Garden
Craftsman model 917377411 front propelled drive not engaging
Craftsman model 917377411 front propelled not working,belt is spinning pulley mounted on transm and handle lever is operating plastic linkage on transm. what is most likely problem keeping front wheels from engaging.
    Problem Solver:
  • 11 Answers
I took mine apart today . Right front wheel is worn completely away on the inside drive teeth. The left front is half gone. I ordered two wheels for 19.99 each with free shipping . Sears has them on back order .
Posted on May 17, 2012
  • 760 Answers
On your model I beleive these wheels are driven with small gears inside the inside diameter of the wheels. If the shaft is turning, then you probably have a gear problem. Remove a wheel and inspect both the wheel, and the small gear. They are prone to wear.I'd suggest replacing all four parts if worn.
Posted on Jul 18, 2010
  • deecamp127 Jul 18, 2010
    Thanks i will check,but i probably needed to check shaft don't think it is turning,neither wheel is
    turning and both had been working.Thought probably something in transmission but really don't know what to look for.
  • Tom W Jul 19, 2010
    Oh, I tought you indicated the drive shaft was turning. Yes if the driveshaft is not turning, and the input pully is , be sure your cable is pulling the lever on the transmission.
I have a Craftsman front wheel self propelled mower. The front wheels no longer turn either in self-propel or in manual push mode. What can be done to fix this?
Take a good look at the wheel assembly. Is it rusted on from being left exposed to the elements? Remove the cover for the self propelled mechanism. Is the drive belt intact? Try turning the small pulley.
Aug 20, 2016 | Craftsman Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
The self propel system slowly stopped working and now doesn't work at all, what could it be?
You didn't specify the make or model of your mower, but generically speaking for self-propelled walk-behind mowers, the drive belt or the front wheel gears can wear out after several years of use. The drive belt could also be loose or off the pulley. The belt and the front wheels can usually be replaced.
You can remove the drive pulley cover and see if the belt is off.
The other components that make up the drive system are the gearbox and the engagement cable. Sometimes the cable can get get out of adjustment or come loose.
Jul 23, 2015 | Garden
Why are the front wheels on a craftsman rotary power-propelled mower hard to turn but after you start the mower and wait 2-3 minutes they start to turn Model NO. 917376673?
The drive belt may have come off the pulley. If that's the case you will need a new belt and possible the retainers that keep it in place.
Feb 28, 2015 | Craftsman Garden
My craftsman 22" self propelled
Your problem is at other end . Engagement problem is probably due to a loose belt. Make adjustment in that area of mower. GOOD LUCK.
Jun 16, 2011 | Craftsman Garden
Front propulsion not engaging
This is probably a belt driven machine...remove the cover. (could have Torx screws). and see if the belt is on the lower engine pulley and is on the pulley to the drive transmission...If OK, then check the action of the spring that helps engage the transmission.
Aug 12, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Self-propell won't work
broken or worn out worm/sector gear most likely.
can you spin the drive pulley on the transmission and see if the wheels turn? If they dont spin you have internal damage or wear. If they do spin you either have a worn out drive engagement cable or it has come off the transmission.
good luck and be careful!
Jun 29, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Front ppropelled mower
You dont adjust the belt,you adjust the cable that moves the pulley into the belt. There will be a small single bracket close to the engine side of the mower that holds the cable in place. Simply loosen bracket and move cable until pulley contacts belt enough to engage self propel.
Aug 08, 2009 | Toro Lawn Mower With Toro Power Tools
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
367 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
