Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
My AC unit is 3 years old. its set at 72 but wont go below 78 degrees. im in Las Vegas...Help
  • 99 Answers
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the AC manufacturer or a service person to verify the cooling system is operating correctly.
Or call the techline 18002842925.
Posted on Jul 19, 2010
Our upstairs Central AC unit will not cool below 80 degrees. Everything is blowing fine. It is 89 degrees outside today. The air coming in thru the ducts is 80 degrees. The downstairs unit blows 70...
you will need a thermometer, you can use a meat therm.take a temp reading of the air going into the return and then coming out of the supply at the unit, it should be at least 15 to 20 degrees cooler in the supply, if not it may be low on refrigerant also check filter and return duct make sure your not pulling air from attic
Jun 30, 2013 | Heating & Cooling
The temp setting shows 78 degrees,lower to 72 degrees /it stays for 15 sec and returns to 78 degrees no codes
you may not be giving the a/c enough time to cool down to 72 the reason it goes back to 78 is that is the temp in the room at that moment put on 72 and give it about 20-30 min. to see if this helps
Jul 03, 2011 | Sharp AF-S120FX Air Conditioner
We have had this unit for 3 years. We have had it serviced with freon and cleaned each year. The problem is that the air blows out of the vents but it is not cold. Well, for example, it was only 78 outside...
Hello, it is possible that the unit may be undersized for you home and not being able to keep up with the indoor heat load. The only way to determine thia have a hvac contractor do a cooling load calculation on your home. I have seen many units undersized that cause this problem.
Apr 09, 2011 | Goodman CPLE24-1 Air Conditioner
AC Thermostat is set to 78 but wont cool past 79 or 80
If your unit is running 24/7 you are either low on charge or the unit is to small for your house.
A 20° temperature difference is about normal for the room air vs the air coming out of the ducts, but the room air and the leaving air should keep getting colder and colder.
An air conditioner should cycle approximately 3 maybe 4 times in an hour if it's properly sized.
As for the thermostat thermometer they are very cheap and are more for reference than actual temperature, so if 78° is not comfortable, then you should set it lower but not rely on thermostat being accurate or what the thermometer is saying as long as it is consistent.
The air conditioner and thermostat can also be set below 78°, there's a lot of people set them at 72° and below with no problems.
the only thing is if you have real low humidity you'll need to watch indoor coil or the suction line (the big line) on your outdoor unit and make sure it doesn't freeze up on you.
Sep 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
I have a new Goodman GasPack heating and A/c unit. I turned the a/c on for the first time this year and I'm having problems with the theromastat. When it is set at any set point say 77 the a/c comes on...
If the space temp is (example) 72 degrees and you set at 80 degrees the unit should not come on. The A/C comes on when the space temp gets 2 degrees above setpoint temp. What type of tstat was installed digital or old syle mechanical. I'm leaning more towards a short in tstat wiring
Jun 04, 2009 | Goodman CKL60AR60 Air Conditioner
Thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Mar 19, 2009 | Kenmore 72059 Air Conditioner
What tempratues should be set on a honywell 4 cycle thermost during the summer months
As a general rule set your t.sat 20 degrees below outside temp. Leave at this setting 30-45 minutes. Move down until comfortable no lower than 10 degrees below outside for 30-45 minutes. Unit should cycle normally. If it runs continuously then raise the t.stat 3 or 4 degrees up. The national average is 75-78. I usually keep mine set at 80 during the day here in Georgia and 74-78 at night...
Jul 03, 2008 | Honeywell Heating & Cooling
Inside fan runs constantly on my AC
Raise your thermosat to about 78. Also check to make sure the thermostat is set to auto and not on...
Jun 12, 2008 | Whirlwind FH-778 Air Conditioner
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
518 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Heatmeister99
Level 1 Expert
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
