Question about Microwave Ovens
Our ge JVM140 microwave is taking twice as long to heat sounds much slower and the light inside is dimmer. I noticed that the lights in the house have recently been dimming when the a/c comes on too. Could this be the problem or is it the micro?? It's at least 10 years old. Please help if you can.
  • 2,750 Answers
I would suggest your AC should be hooked to a separate service wire. If you have too many high powered things on a service wire then you could even cause a fire. do you have a hundred Amp service running your house? if it's a sixty amp it's not strong enough to run an AC. Older homes are not usually set up to run an AC. I feel it's not your microwave.
Posted on Jan 25, 2018
2 Suggested Answers
SOURCE: Trying to remove an old
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
Posted on Apr 08, 2011
My GE model JVM1790SK Microwave randomly died yesterday. I had just finished cooking something, started it again, and while the timer started counting, the over did not start. Any idea what this cou
Had you noticed that it was getting weaker? Taking longer to heat a cup of water/coffee? If so then the magnatron was getting weak and gave up the ghost. They are expensive, probably cheaper to get another oven. the other likely failure component is the capacitor. Careful they contain power even when unplugged. Caps are not that $$. good luck
Jan 03, 2015 | GE JVM1790SK Convection/Microwave Oven
Microwave causes lights to dim and slows down
Power surges should be checked with a voltmeter, however, I repaired a 30 year old MW doing same thing. Took out the control board, examined solder connections, found a suspicious solder joint, that had an incomplete circle around connector, added a little solder, works like new, friend amazed!
Jan 29, 2014 | GE Microwave Ovens
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
Dec 11, 2010 | General Electric Microwave Oven
The microwave does not heat..after reading everything about the magnetron my one question is this an easy job that an ammature can tackle or do I really need to call in a service man?
I'm having the same problem with my microwave -- GE JVM1533WD 002.
The inside light, cooling fan and turntable are all working but it is no longer heating food when the Start button is hit.
The unit is noticeably louder than normal, too.
Any suggestions? Thanks in advance for your help.
Jun 09, 2009 | GE JE1660 Microwave Oven
I have a GE microwave. Model # JVM1870BF02 and the interior light is not working. I see a circular disc in the roof inside the oven but, can not seem to slide it and remove to replace the light bulb. Can...
THAT DISC ACTUALLY HOUSES THE ANTENNA FOR THE MICROWAVE ENERGY. NO NEED TO GO INTO THAT. TAKE OFF THE FROM GRILL AND IN THE MIDDLE THERE IS A METAL COVER WITH ONE SCREW. TAKE THAT OUT TO ACCESS THE BULB.
Jan 25, 2009 | GE Advantium 120 Convection/Microwave Oven
My GE Spacemaker Microwave is not getting enough power
the dimming of the light indicates a big amount of current being drawn by the magnetron. can you see sparks inside the oven?..it looks like the magnetron is shorting out with the ground. what makes it short to ground could be in the wave guide cover...look for some dark spots or accumulation of carbon from old food residue which becomes carbonized due to repeated heating. carbon is a conductive material that shorts the magnetron to ground.
i hope i was able to help
Jun 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not working, please suggest
Your magnetron tube has failed. According to the warranty on the Profile Series microwave ovens, the magnetron is covered for 5 years from the date of purchase, but labor is not included. I would call GE Customer Service and when they ask for the model number (which begins with JVM) and the serial number, be sure to give the date of purchase as the date you closed on your house. If they insist upon charging you for a service call and labor, I would call my builder's Customer Service Department and demand (very nicely) that they intervene with GE to waive the service and labor charges. That worked for me (Lennar Homes).
Jun 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
