Question about LG WM2688H Front Load Washer
Water retains in the drain tubes and causes a bad odor. We are always having to drain the tube..can you advise on what else we can do. Thanks.
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@@@
Posted on Sep 28, 2010
  • Kids3walters Jun 13, 2011
    I should read this long time ago to prevent the mold on my front load washer thank you anyway
Ice builds up under the pull out freezer drawer then melts allowing war we to flow onto the floor
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 16, 2014 | Maytag MFD2560HES Bottom Freezer French...
Anyone know how to permanently remove odors from car/van seats/carpets. what has worked for you? please advise.
good question,
i hand one really bad seat, (milk spelt by PO)
i even remove the cushion and cover. ran cover thru washer mach.
and the seat i put in a huge tube outside,
i soaked it in TIDE. hot water.
then when done , rinse
i used that chem called, dog/cat pee enzyme remover.
this attacks the proteins in the milk.
but really ,it does matter the cause of odors, infinite.
and the solution (no pun)
also barcarb soad soaks.
lye always works but kills plastic.
my last rinse was with PineSol (pine oil)
then let it bake dry on the roof of home, in hot summer sun.
i solved mine, but took hard work,
but was paid back on resale, no funny nose sniffs, by buyers.
sold car for more than paid , after 6 years. (mx5)
Sep 28, 2013 | 2006 Honda Odyssey
I have an Amana refrigerator, model #ABB1922FEB2. The ice that is made by the automatic ice maker has a foul odor and taste. The water that comes out of our faucet tastes fine, and it's the same water...
Off-taste, odor or gray color in the ice New plumbing connections? New plumbing connections
can cause discolored or off-flavored ice.
Ice stored too long? Discard ice. Wash ice bin. Allow
24hours for ice maker to make new ice.
Odor transfer from food? Use airtight, moisture proof
packaging to store food.
Are there minerals (such as sulfur) in the water? A water
filter may need to be installed to remove the minerals.
Water filter installed on the refrigerator? Gray or dark
discoloration in ice indicates that the water filtration system
needs additional flushing. Flush the water system before
using a new water filter. Replace water filter when indicated.
See "Water Filtration System
To purchase a replacement water filter, model UFK8001AXX-750,
contact your dealer or call 1-877-232-6771 U.S.A. or
1-800-807-6777 Canada
Good luck Please rate FIXYA Thanks
Mar 28, 2011 | Refrigerators
2004JEEP WATER LEAKNG PASSENGER SIDE FLOOR
its likely the drain tube is clogged , its under the vehicle ,it
allows a/c water to drain , your local auto shop should
be able to clear the tube out .
Spray some lysol at where the passengers feet would be
and eliminate odors as well.
Aug 12, 2010 | Jeep Cherokee Cars & Trucks
Refrigerator and freezer have a bad smell. I
Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travels down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Mar 31, 2010 | Kenmore 64802 Top Freezer Refrigerator
Laundry tub has a bad smell/stinch like mildew. Has gotten into towels and other laundry. How do you get into the machine to see if there is lint buildup or what is causing this? Have used numerous odor...
Water left in bottom of washing machine should not be more than a tablespoon or so. Have you tried washing a full cycle with EMPTY washer, 1 gallon of clear distilled vinegar and 1 pound box of baking soda...the plain one on the grocery shelf. You got some drain tube that seems to be harboring this smell, which feeds back to your clean clothes. Empty the washer immediately upon washing being done. Always leave your lids or doors open. You may have to change out the tubing/drains from INFLOW and OUTFLOW. This is all under the assumption you have a front loader. I don't believe this would exist with regular top loader as gravity pulls all to the drains.
Oct 17, 2017 | Kenmore Washing Machines
Wet carpet
Your drain tube for the air conditioning is plugged up, and instead of draining on the ground, it's leaking on the carpet. You need to go under the car and locate the tube (it's on the passenger side, in front of and below where the front passengers feet would be. You will need a long thin wire to clean out the blockage.
Aug 25, 2009 | 2006 Dodge Stratus
Have water in the passenger floorboard when the air conditioner is running.
Your vehicle has an evaporator drain tube which can clog causing the condensate water to retain and drip from the housing onto the carpeting.I have seen almost everything known to man find their way into this tube .The strangest to date for me was a mouse that used this tube as an entry to his new condo and apparently went in and out successfully a few times by evidence of dwelling in the actual evaporator housing.
Jul 16, 2009 | 2006 Volvo S40
Whirlpool Refrigerator Model # ET21PKXGN00
HI thanks for your question. the problem is with the drain tube, from freezer to the drain pan ,located at the back, by the compressor. to repair. turn fridge off, for 24 hrs. pull fridge away from the wall. clean all the coils. locate the drain tube, by the drain tray. get a small plastic hose, shove the plastic hose up the drain tube. and blow, to dislodge any debris clean the tube thanks the appliance doc.
Oct 15, 2008 | Whirlpool Refrigerators
9 yr.old GE profile top/bottom refrigerator
There could be many things that cause these symptons. Defrost timer not working, bad door seals, or lack of freon. It may be less expensive to replace the frige than repair it.
Oct 20, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
LG WM2688H Front Load Washer Logo
123 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
